Does anyone have any good suggestions for finding the studs in plaster walls? I'm trying to install some shelves in my kitchen (above doors and windows), and am having a terrible time finding the studs. A studfinder does not work. The tap and listen method is hard, not a whole lot of room for using it. Any other ideas out there?
Thanks,
Thanks,
The first wall I am working on is ALL window and door, except for a few inches at each end. Going from left to right, a door, then two windows. I have tried drilling test holes (seems to be necessary everywhere in the house), and only found 1 stud so far, just to the right of the door. I was expecting to find studs near both sides of the door and windows, no such luck. Also, below the windows is the cabinet with the sink, so I can't check down there, not that it would tell me much anyway. Most of the house seems to be on 16" centers, but the second floor definately has areas on 24" (non load bearing, of course). This gets very frustrating. Fortunately, the next wall I switch to, I can see some of the studs from the attic. That section will be easy.
