Tablesaws and Wheelchairs
  • Tom Hintz
    • 549
    • Concord, NC, USA.
    JR Mapes,
    Welcome to the forum!
    Over the last three years I had been working with a young man who was dealing with cancer of the spine that put him in a wheelchair.
    Before that he had done quite a bit of woodworking and did not want to give it up. As you are finding out, that can mean considerable adaptation.
    For a table saw he got a Bosch job site model 4000 and we built a mobile cabinet that placed the saw lower and cantelevered (SP?) outward to make access easier with the chair. To counterbalance the saw we added a cabinet across the back that he could also access easily.
    The simplest project was building a lower workbench, again with a projected top on which he could do his hand work and use benchtop machines.
    To make access to the storage easier we put pull-out shelves in the cubbies on heavy full-extension slides.
    He did very well with this arrangement and made lots of nice things for his wife and kids as well as donations to his church.
    Unfortunately, he lost his battle with the cancer last winter so we did not get to figure out the lathe he wanted.
    I expect you will find lots of ways to handle your needs. One of the things that most impressed me about the fellow above was his determination. When he decided the disease was not going to stop him, he came up with ways to get around it I would have never thought of.
    Good luck!
    Tom Hintz
    NewWoodworker.com LLC
    • JRMapes
      • Jun 2005
      • 6
      • Arcadia, KS, USA.
      Hi Tom, thanks for the reply.
      Sorry to hear about your friend. Cancer of the spine is also what nailed me. Fortunately I was able to beat it.
      I really like the cantelevered idea. I saw something simialar in Family Handyman a while back for benchtop saws. What they did was take a couple of 2x6x12's IIRC , notched them out the depth of the ts plus depth of rear rails and mounted them under the wings of the TS next to the body. They scrwed (countersunk)thru the tabletop to the two-bys. The notch was deep enough to line up the rest of the top of the two-bys within 3/4" of the height of the saw table, then fixed either 3/4 ply or mdf to the two-bys (countersunk), then mounted the mdf "table" to a couple saw horses. it looked like they used just some hvy screws countersunk thru the mdf into the sacrificial 2-bys that were on the sawhorses. One sawhorse was just behind the rear of the saw and the other was within a foot of the end of the 2-bys.
      This not only made a cantlevered benchsaw but it also provided a 10' outfeed table. To break it all down (once the 2-by rails and mdf were permantely secured together), all you had to do was dismount the TS from the 2-bys (4 screws) then take the table off the sawhorses (4 screws). It looked like they were using the Bosch 4000. A very cooll idea, or so i thought. But i dont know if i would want to try that with some of the other jobsite saws. I'd be afraid 60 or so pounds would be about as far as i would trust that setup.
      I can just see trying ot rip a full sheet of 3/4 ply, getting it in a bind about a quarter of the way thru then have the weight of the saw plus the weight of the ply trying to kick back. Unless you spiked the rear sawhorse legs into the ground it seems that would be to much of an open invitation to major tippage. I suppose if you put runners between the legs of the sawhorse you could have a couple sand bags to toss across the runners... just to be sure. I would also prbably add some cross bracing under the mdf table so it wouldnt rack on you and that would also make you have to get the horses level so it would sit right. Of course i tend to lean toward the belt AND suspenders mentality. Heh.
      \"There are only two infinite things in the Cosmos: the Universe, and human stupidity. And Im not that sure about the Universe. - Albert Einstein\"
      • JRMapes
        • Jun 2005
        • 6
        • Arcadia, KS, USA.
        I forgot to mention, those 2x6's were set on edge not on thier face!
