Wobble dado blade
  • Rounder
    • 1287
    • Sanford, FL, USA.
    Wobble dado blade
    I have the SD206 stacked dado set for my BT3100. Last night in my woodworking class, the instructor used a wobble dado blade. I didn't get to see the dado it made up close, but it appeared to do teh same job as my stacked dado would have. It also appeared a lot easier to set up.
    Why are stacked dado's prefered to wobble?
    George AKA Rounder
    "Amarillo Slim, the greatist proposition gambler of all time held to his father's maxim; You can shear a sheep many times, but you can skin him only once."
  • Eric
    • Jun 2003
    • 653
    • Cocolalla, ID
    • Grizzly G0691 & BT3100
    The wobble dados that I've seen don't leave as clean of a cut as a stacked set. The bottom of the dado will also be wider than the top because of the way the wobble dados wobble.
    I think they're fine for doing shelf dados and the like, although, I think I've read on the forums here that they shouldn't be used on the BT3.
    • don_hart
      • 1005
      • Ledayrd, CT, USA.
      Two major reasons.
      1. They greatly increase the vibration of the saw. If you have a massive cast iron cabinet saw this is not as big of a deal
      2. They will make fairly decent dados but only within a limited range. The farther you get from the dado width the unit is really deisgned for (usually 3/4") the more rounding you will get on the bottom of the dado.
      Don Hart
      You live and learn. At any rate you live.
      www.hartwoodcrafts.com
        I have both. The wobble (a craftsman) is fast and easy and gives me good cuts for the designed range. http://www.sears.com/sr/javasr/produ...id=00903261000
        • Popeye
          • 1848
          • Woodbine, Ga
          • Grizzly 1023SL
          I have the high end Craftsman 3 blade adjustable George. That may have been what he was using. Works as well as a stack IMO but I'm glad I didn't pay the $200 they get for them. Alittle horse trading on my part. Pat
            • 22047
            Eric was wrong. They do leave perfectly vertical sides.
            However, it is true that they leave a slightly rounded bottom,
            the curve has a radius of 4".
            For a 8" wobble dado cutting a 1/2" wide groove, I calculate the center bottom will be .008" lower then the sides. Its small (1/128") but visible rounding.
            I have a Sears twin-blade excalibur. Doesn't shake the saw.
            If you pay $10-$20 for one then it will probably shake but if you pay $75-100 for one then it will be well balanced.
            Personally I think they are over-villified, in general.
            But it is a bear to get them on the BT3 arbor with the blade shroud!
            • jhart
              • 1715
              Also have the Sears excalibur, which I use on my RAS. Just bought the Avenger 6" dado set during the winter. Without a doubt, the wobble is easier to set up and use on the RAS, than the Avenger set. Avenger set did a great job on the dados I did on a set of bookcases. They came out perfect. The wobble set does not do as great of a job, but usually I'm not looking for as precise a cut with the wobble and using it on smaller pieces (short dados).
              The excalibur cost about $90.00 a couple of years ago and the avenger was on sale at Rockler's on Thanksgiving weekend for $29.95.
                I have a wobble dado that is ground to produce a flat bottom dado at 3/4 inch width. Most will produce a flat bottom at something like 1/4 inch. At any other width, the grind of the teeth is such that there is a curve to the bottom of the dado. I find it more difficult to adjust to a specific width, however. I have to remove it from the arbor, loosen a couple of screws on the sides, rotate one side versus the other a little, tighten the screws and reinstall on the arbor. I never know exactly what affect I will have on the width of the dado. With my Freud stacked set, I measure the width of the dado I cut to test the width and add or subtract shims of known thickness to get what I want. I only have to remove the outer blade, most times, for shim insertion. I hardly ever use my wobble dado mainly because of the difficulty in adjustment. Maybe I'll give it a try this weekend. If I could get it set up for one type of plywood or solid wood and then just leave it that way, it would help. I think my wobble dado also tends to cut more roughly because of fewer teeth but that can be somewhat offset by feeding the stock more slowly.
                • Eric
                  • Jun 2003
                  • 653
                  • Cocolalla, ID
                  Doesn't surprise me that I was wrong Loring, but the dadoes that I was getting from a wobble blade that a friend of mine had on his Delta did give a wider bottom.
