Converting Rise/Run to Degrees?
  • Mike P. Wagner
    • Mar 2005
    • 65
    • Raleigh, NC, USA.
    I is there a quick rule for converting rise/run (the way an angle is specified for rafters 5" per foot) to degrees? I think mathematically its the arctan. But I have to believe that carpenters have been doing the conversion for years w/o a calculator.
    I'm cutting come rafter plates on my bt3100.
    Thanks,
    Arctan(rise/run) = degrees
    rise and run must be the same units
    so if rise in inches and run in feet
    then Arctan(rise/(12 x run)) = degrees.
    make sure calculator is in degrees mode, not radians or other angle modes.
      Sure, they do it "visually," using a framing square, or a speed square.
