processing rough lumber
  • Stytooner
    Roll Tide RIP Lee
    • 4301
    • Robertsdale, AL, USA.
    quote:Originally posted by LCHIEN
    Sam says this forum discussion group is for testing the forum.
    1. I will post and verify I can't edit.
    Theory is wrong! This is an immediate edit to the original post without there being any reply!
    2. I will then reply to my own message and see if I can then edit the original
    Here goes...
    Talking to yourself is one thing...answering yourself is a whole nuther problem.
    http://www.leestyron.com
  • TheWoodWizard
    • 296
    • WilkesBarre, Pennsylvania, USA.
    Yep !!That's scary !!Getting answers while talking to yourself is a definite no-no.I think I heard somewhere that,that was the reason for starting institutions,and I'm not talking about the higher learning type.
    Things worth doing,are worth doing right the very first time!!
    If things get better with age,then I must be approaching magnificent!!
    • Sam Conder
      Woodworker Once More
      • 2502
      • Midway, KY
      • Delta 36-725T2
      Here goes...
      Loring,
      Are you saying that at times, the icon pointed to below with the red arrow is not visible?
      <center></center>
      Sam Conder
      http://www.bt3central.com
      Sam Conder
      BT3Central's First Member
      • aleuni
        • 321
        • Miami, FL, USA.
        I always thought it was better to have a converstaion with your self rather that an IMAGINARY friend.
        My reasoning was that at least you exsist
        keep talking Loring.
        Which reminds me about
        Roses are red
        Violets are blue
        I love you
        and so do we
        Alex
        "If you want something done RIGHT you have to do it yourself
        and if you want it NOW you have to do it by yourself." -me
        Miami, Florida USA
        Alex
        \"No Idea is a good idea until it is your idea\" -me
        http://community.webshots.com/user/aleuni
          quote:Originally posted by sconder
          Loring,
          <center></center>
          Sam Conder
          Yep! That's what I'm curious about - when it happens.
          • Sam Conder
            • 2502
            • Midway, KY
            • Delta 36-725T2
            Is there a "hole" there, or are all the icons appropriatly spaced, just no Edit icon?
            Sam Conder
            Sam Conder
            • AttilatheHun
              • 831
              • Farnham, Surrey, United Kingdom.
              quote:Originally posted by StytoonerTalking to yourself is one thing...answering yourself is a whole nuther problem.
              Just don't start interrupting yourself!
              AtH
              This looks complicated, better get a bigger hammer
                Sam Conder
                all the icons appropriatly spaced, just no Edit icon.
                  Alex
                  Sometimes, if I want an intelligent conversation, I just have to talk to myself; and if I want an intelligent answer, I also have to answer myself!
                  Loring, I know how you feel; Keep talking to yourself!
                  Hank
                  • RickT
                    • Jun 2003
                    • 175
                    What are the best way(s) to process rough lumber? My woodworking so far has been with Home Depot and Menards lumber and sheet goods. I bought Delta mobile bases that use hardwood for the sides, so I made my first trip to my hardwoods store and purchsed some fairly rough 8/4 hard maple. I have a 6" jointer and 13" planer, as well as my BT3100. What are some of the best ways I should process the lumber so I end up with flat, straight 1 1/2" square pieces for the sides of the bases? I haven't yet unboxed my jointer because I was planning to assemble it on the mobile base, but I might need the jointer to first joint/plane the lumber. How would you guys proceed? Also, what do you do to "clean" the lumber? I'm not sure I want to run rough lumber with dirt through my new planer. [:I]
                    Thanks so much,
                    Rick
                    • Otter
                      • 865
                      • Cumming, GA, USA.
                      • Delta Left Tilt UniSaw
                      I would love to write out the whole thing but reading it is easier. Here are a couple of links to the process that I use. and you have all the tools needed.
                      http://www.gwinnettwoodworkers.com/4square_wood.html
                      and another
                      http://www.mydiscounttools.com/estor...ing-lumber.asp
                      and my all time favorate, this guy has pics and hints:
                      http://www.inthewoodshop.org/methods/wwc01.shtml
                      hope this helps
                      T.E. Lawrence
                      • Jim Boyd
                        • 1766
                        • Montgomery, Texas, USA.
                        • Delta Unisaw
                        Otter has given you some good links. I wiil add to the other part of your question. I use a wire brush to get the dirt off of the board before jointing. Most of my wood starts out pretty dirty and the brush has been working well.
                        • HarmsWay
                          • 878
                          • Victoria, BC
                          I second Jim's wire brush suggestion. Also do a quick check for staples, although that's usually not an issue with rough lumber. Not any problem for carbide tipped blades but does a real number on jointer and planer blades.
                          Bob
