I need to do something about protecting what hearing I have left (which is most of it, although I am starting to notice some slight loss that is presumably due to advancing years). The trouble is, I'm not sure what kind of protective device will work best.
Muffs look like they'd be easiest to put on and take off, meaning they might actually get WORN, but from wearing stereo headphones I wonder how prone they'd be to slide off when I bend over. They could be hot in the summer, too.
I've worn foam earplugs on long, top-down trips in my Miata, and they work reasonably well. But it takes a bit of fiddling to get a good seal, and the ocean-in-a-seashell sensation they impart is a little creepy.
The "headsets" that consist of foam plugs mounted to a thin plastic band look like they'd be quick and easy to put on and take off, but I seem to remember reading somewhere that many of these are not very effective unless you take the time to ensure a good fit, the same as with loose foam plugs.
And I guess there's always the custom-fitted hi-zoot earplugs option. Not cheap, but the usual argument about them being cheaper than medical bills applies.
What have some of y'all used that works? Or doesn't work? I'd be especially interested in the comments of anyone who has tried more than one system.
) and I don't want to lose the rest any time soon. I tried the headset muff type but they get too warm after a short time.
