No Router Fence!
  • Jack1064
    • Jan 2008
    • 36
    No Router Fence!
    The BT3 which I just bought did not come with a router fence, or the attachments to put on the rip fence, What do you guys suggest I do? Order the parts or build my own fence for the router table, and if build my own, do you guys have any plans?
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    the "router fence" that comes in the accessory kit is worthless so you need you build your own.
    I usually just clamp a piece of material to the fence or table with a setup similar to the way they do it on "the router workshop" tv show.
    • steve-norrell
      • 1001
      • The Great Land - Alaska
      I agree with Tom's suggestion. Clamp a piece of MDF to the rip fence and treat it like a "sacrificial fence."
      If dust collection is an issue, then something with a dust port would be more appropriate. I have had excellent results with the Bench Dog Profence (http://www.benchdog.com/profence.htm) and there are plenty of plans for home-made fence on this website.
      You are not missing much without the Ryobi router fence.
      Regards, Steve
        I used 1" baltic birch attached to the fence w/ the accessory kit t-nuts. I made it so it is no higher than the fence, and I leave it on the fence at all times. I use a down-draft box for dust collection and have found that I really have no need for fence-based DC w/ the down-draft box.
        • Jack1064
          • Jan 2008
          • 36
          Do you have a picture of this?
          Thanks,
          • Lonnie in Orlando
            • 649
            • Orlando, FL, USA.
            I don't use the rip fence for my router fence.
            I clamp a separate fence to the router accessory table with 6" bar clamps. The fence is on the right side of the router. This gives a large work surface on the left side of the router. I can fine tune fence placement with this setup easier than using the rip fence. Just requires a little tap with a hammer to fine tune the fence placement. Then tighten the clamps.
            I hot glued some blocks under the table so the clamps don't bend the table and to allow the clamp jaw to clear the side of the acc table.
            - Lonnie
              Thanks,
              Post #20 in this thread:
              http://www.bt3central.com/showthread.php?t=17598
              • luteman
                • Dec 2007
                • 145
                • Northern Michigan
                I use a Freud router fence. Excellent adjustability of both fences as well as built in dust collection and finger guard. I had to drill and tap two holes in my BT table top in order to mount the Freud fence.
                  I agree with the other posters - build your own. I made a simple one that fixed to the right side of the rip fence. You can either do it with clamps or with T nuts.
                  It will make a good first project for your BT.
                    I tried a fence that attached to the rip fence but did not like it. It made the rip fence heavy and I could not use the saw well with the router fence attached. I have an extension table and my router is mounted to it, well away from the saw blade. I made a router fence that attaches to the extension table with knobs with studs that go into t-nuts mounted in the extension table. I like this much better.
                    You can see pictures if you follow the link to the old articles. My saw is "Spruce and Sandeply" if I remember correctly.
