Advice on circular saws
    Can anyone give me some advice on replacing my old circular saw, the arbor has started to wobble -it will still give a fairly clean, but I want to start using a c.saw to cut up plywood panels before using the table saw for final cut.
    So any advice, pros & cons, sidewinder or not, etc.
    Any help would be much appreciated!
    Thanks
  • radhak
    • 3061
    • Miramar, FL
    • Right Tilt 3HP Unisaw
    Festool. nuff said.
    - Aristotle
      Ok, let me clarify......cheap saw - anything less than $200 - Festool is more expensive than (2) BT3100's!
        My DeWalt is a very nice saw. My dad has a Makita but I think my DeWalt has a bit more power.
        • mpc
          • 1018
          • Cypress, CA, USA.
          • BT3000 orig 13amp model
          If the saw is otherwise healthy - and one you liked - take it apart and see if the bearings can be replaced. I'll bet they are plain old "sealed" bearings with standard bearing numbers stamped into them. NAPA auto parts stores, real hardware stores (Fastenal, McMaster-Carr, etc.) can order them. You might need a "bearing press" to remove & install them... local auto machine shops and many NAPAs can do that for a few bucks per bearing. You might be able to repair the saw for 20 to 30 bucks.
          New: I'm pleased with my Porter-Cable 325 (?) MAG saw. I like the thick style base plates (compared to the thin stamped metal ones with curved edges) since they don't tend to ride over/under fence pieces.
          mpc
            Mine is an older craftsmen bought at a pawn shop! It served me well as I built my house with it, but its time for a better one. Has anyone ever used or owned a sidewinder type saw?
            • Tom Slick
              • 2913
              • Paso Robles, Calif, USA.
              • sears BT3 clone
              I like my milwaukee sidwinder alot. the PC and bosch are both nice sidewinders. unless you do framing I don't see a need for a worm drive.
              if you never cut anything but sheet goods then buy a smaller 5" saw. they are lighter weight and easier to handle.
                Good point, I believe my framing days are mostly over. Great suggestion on a 5" wouldn't have thought about that. Thanks!
                • maxparot
                  • 1421
                  • Mesa, Arizona, USA.
                  • BT3100 w/ wide table kit
                  Look at the Hitachi with the blade brake. It can be had for less than $90
                  Opinions are like gas;
                    Are any of the hitachi's available with left blade? Where have you found in the $90's range.
                    Thanks!
                    • Slik Geek
                      • Dec 2006
                      • 708
                      • Lake County, Illinois
                      • Ryobi BT-3000
                      I looked at replacing the bearings in my 20+ year old Craftsman (when they bit the dust), but decided against it when I disassembled it.
                      I ended up buying a Milwaukee 6390-21 Tilt-Lok 7-1/4-Inch. I never realized how sweet a circular saw could be. I never would have believed how much nicer it handled than the cheaper Craftsman. The tilting handle, which seemed like a gimmick to me initially, has come in handy too.
                      A 5" saw might be a limitation when you end up working on a deck and want to cut 4x4s or 6x6s.
                      • Tom Slick
                        • 2913
                        • sears BT3 clone
                        Although I stick my by milwaukee recomendation, I was thinking of the smaller PC saw boss which is actually a 6" (not 5") saw, and will cut 2x material. Skil makes a similar saw.
                        http://www.amazon.com/Porter-Cable-3...00114&sr=1-149
                        They also make a tiny trim saw
                        http://www.amazon.com/Porter-Cable-3...00099&sr=1-133
                        Nahm uses this saw quite a bit.
                        • Scottydont
                          • 2359
                          • Edmonds, WA, USA.
                          • Delta Industrial Hybrid
                          I tried a Ridgid a couple of years ago and it is the best circular saw I have ever owned. Lots of power, feels great in the hand, very nice base plate with indexed markings that works great with a saw board or guide. I use mine with a allinoneclamp guide saw baseplate and the the cuts I make with them on sheet goods are my final cuts. 3 decks, a large garden shed and a chicken later and never disappoints. A+ in my book.
                          When it comes to rough cutting lumber of sheet goods to sise I often grab my Dewalt 18V cordless circ. Not much power but very convenient.
                          Scott
                          Edmonds WA
                          No coffee, no worky!
                            I own a couple different B&D circular saws, and haven't been disappointed in the performance of any of them so far, especially with a good carbide blade. I have an older version of this saw (without the laser), and like its durability and price.
                            http://www.lowes.com/lowes/lkn?actio...CSL&lpage=none
                            • gary
                              • 893
                              • Versailles, KY, USA.
                              Got the battery powered Dewalt. I love being able to take it out on the driveway to cut up ply without having to drag a cord with it.
                              Gary
