Looking for a good drill press...
  • rosesunkist
    • 55
    • LaVernia, TX
    I figure that it is about time to get a good drill press. Well, actually I bought one last week, but returned it.
    It was the Ryobi benchtop model DP121L, from BORG. It looked real nice, was not really expensive, but the quality was utter rubbish.
    It had the lasers which were very ineffective. If I set the lasers for one piece of wood and then moved onto a different thickness of wood, I would have to reset the lasers.....useless.
    The lift mechanism for the table, from what I can tell, all are about the same, but this one just didn't work right. I had to tighten the collar down a lot more than I felt comfortable, just to get it where the table would not wobble on the rack. And then I would have to loosen it just to get the table out of the way.
    It had a depth gauge on the (part with the three handles...) hub. I thought it was pretty neat until the handes fell off in the middle of drilling...... Plus the markings on it were printed on a sticker which kept trying to come off.
    And for the life of me, I could not get the bit not to wobble. I even used a brand new $20 1/2" bit and it wobbled. At first I thought the bit might be bent, so I took it back, but replacement was same. I took off the chuck and the arbor and reinstalled them five times. The wobble was the same each and every time. I even used a marker to find the ...wobbliest... part on the bit each time, and each time it was at a different spot, so I know for sure it was not a bent bit. Come to think of it, I probably should have tried this on the chuck....Oh well.
    But one thing I did like about this DP is that it had the infinite speed thing and a digital readout of the RPMs.
    I used it for two days and took it back and now I am looking for a better quality press. I need a benchtop model because of my lack of space. I don't mind paying a bit more, maybe up to $300, but I know quality=$. I have been throwing around the idea of getting a floor DP and finding a shorter column, or even (gag) cutting the full size column. I come to you all because I know the best advertisement is word of mouth and hands-on experience. Please help me!
    Just think of something witty and pretend you saw it here.
    I'v had the three handles come out of the hub on the first two DPs I owned. They just kept working loose. Fixed it by using a couple of wraps of teflon tape (like plumbers use) on each threaded end before screwing into the hub. On the third DP I did that before using it the first time and have not had any trouble.
    CAn't remember where I learned that trick but it works...
    • docrowan
      • Mar 2007
      • 893
      • New Albany, MS
      Thanks for the post on the Ryobi. I have a HF cheapie benchtop, but I've been pretty pleased with it. I wasn't happy with the length of quill travel until I found out from this site most benchtops are around 2.5 inches (at least anywhere in my price range.) No wobble, smooth running, and quiet. Biggest complaint I have is the tilt for the table involves loosening a bolt. However the BORG Ryobi looked like it had the same thing. I don't care about the ratchet gear mechanism for as little as I use the drill press.
      Anyway, I'd eyeballed the Ryobi drill press last time I was in the store, I'm glad to scratch it off my wish list, now a band saw has moved up one more notch.
      - Chris.
      • jziegler
        • 1149
        • Salem, NJ, USA.
        I just got a new Harbor Freight ad in the mail yesterday, and they have their large bench DP, and the floor standing one with the same head on sale again. I have the bench unit 38142. Works well for me, sale price is $150. I think a few others on here may have it as well.
        DPs seem to be some of the better HF units. No infinite speed control, but it is 16 speeds, soe it has a good range. You should probably take a look if you have an HF store near you.
        • eezlock
          • 997
          • Charlotte,N.C.
          drill press
          You might want to check the Wilton 10" #99170 drill press. I have had one
          for almost 2 years now, never had any problems with it. It works great and does everything I need for a drill press to do. I bought mine from WT Tools,
          check on their web site sometimes they are on sale for a really good price.
            Harbor Freight has a floor model drill press with radial movement of the head and rack and pinion table height. You want this thing. I can't find the model number, but if you've got a HF near your home you should check it out.
            • ke4rdb
              • 83
              • Mooresville, NC
              I have the same Ryobi Drill Press, bought it to drill holes in pen blanks. I noticed alot of run out and changed out the JT arbor and chuck with better ones and that took care of the issue. The chuck that comes with the drill press is not very good. The laser on mine works well and I have no issues and love the beltless speed change ( I believe this is called a Reeves Drive (sic)) as for the height rack it works as well as any.
              JW
              JW
              Credidi me felem vidisse!
              • dramey
                • Oct 2005
                • 42
                • Soldotna, AK, USA.
                I have the Ryobi drill press and am completely satisfied with it. To get rid of the wobble of the drill bits, you must remove the drill chuck and arbor and clean the cosmoline from them. You should also clean the cosmoline from the table, base and column, and the inside of the table support and then wax them. I used Johnson's Pate Wax and have a very smooth operating bench drill press. The lasers needed minor adjustment and works at any table height. The finish of the drill press is not as good as my 17" floor drill press, but the function is every bit as good.
                • ragswl4
                  • 1559
                  • Winchester, Ca
                  • C-Man 22114
                  I have this drill press. Occasionally goes on sale for $149. There is also a bench model, same head and motor but costs a little more for some reason.
                  I have been happy with it, good power, no vibration and no run out. Drills nice straight holes. Just showing what's out there.
                  http://www.harborfreight.com/cpi/cta...emnumber=43378
                  RAGS
                  Raggy and Me in San Felipe
                  sigpic
                    Here's the bad boy. It was in today's flier at $239.99, which seemed to be list price.
                    http://www.harborfreightusa.com/usa/...displayItem.do
                    • Thom2
                      • 1786
                      • Stevens, PA, USA.
                      • Craftsman 22124
                      Here's mine ...
                      http://www.harborfreight.com/cpi/cta...emnumber=43389
                      paid $170'ish on sale with a coupon ... VERY HAPPY with it
                      a side note to JR ... I had a bench model of that radial for several years, LOTS of flex on that thing, also it's only 5 spd, WAY too fast for big bits, I sold it to buy the 43389 ... just FYI
                      • rosesunkist
                        • 55
                        • LaVernia, TX
                        Thank you all for the many responses. It is kinda hard for me to shop for large tools like this because I like to buy from stores, and not online. It makes returns much easier to just bring it back into the store.
                        Has anyone had experience with the Delta DP350?
                        I was also thinking about the HF model.. http://www.harborfreight.com/cpi/cta...emnumber=38142 .. since I have a HF store nearby.
                        Oh and LCHIEN, it was not a handle that fell off, it was the entire handle assembly and hub. That there was the clincher for me to return it. Maybe the unit I bought was just a lemon all over?
                          Well, burst my bubble! That radial head thing just looks so cool...
                          • jziegler
                            • 1149
                            • Salem, NJ, USA.
                            Originally posted by rosesunkist
                            T
                            That is the model that I have. Take a trip to the store and check it out. It's on sale right now too. I don't use mine heavily, but it has done all I have asked of it so far. It's big and heavy for a benchtop unit. The speeds go low enough for the big bits. No fancy features, but a solid machine.
                            • tropicaffair
                              • 85
                              • Gloucester, MA, USA.
                              I've had the Delta DP350 for 2-3 years now and up until 2 weeks ago I would have recommended it. The speed adjustment mechanism is one belt and two pulleys. The rear pulley is a split pulley held together by a retaining spring held by a c-clip. The fron pulley is adjusted by the knob on the front of the drill press to control speed. Basically it adjusts the speed by adjusting the tension on the drive belt.
                              Two weeks ago the rear pulley went off track somehow, I disassebled it/reassembled (in the process losing the special sized c-clip, ask me how I know)ordered replacement c-clips, installed one and have been using the past week until it happened all over again last night. It's time for another disassembly session. If I find a solution I will again be very happy with this unit. Sorry for the rant, but I really like not having to change the belts.
                              Russell
