I'm not trying to make an argument so please don't take it like that but when you spill something on the kitchen floor it doesn't gel up and harden like glue does. I'm not trying to step on any toes just telling you what i learned and what we use.
Also when the grain in that section raises and then you sand it when it dries to the rest of the section that wasn't hit with the water you raised the grain in one part but not in the other so when you hit it with the sander you are flattening it down but not the other so if any other part has moisture put to in the form of humidity or any other type of water it will be a bit higher...this may come in to effect alot more in a water based finish which will raise the grain.
But like i said just tryin to pass on the knowledge that I'm getting not saying it is the best way. I would also like to see a comparrison.
