What is the difference between using 1/2" and 1/4" bits in a routers? If you have a router that only uses 1/4" bits the obvious choice is the 1/4" bit. But if the router accepts either, is there a preference? Does one work better/easier than another? The reason I ask is that I am looking at the starter kits at Holbren and both the 1/2 and 1/4 starter kits that I am considering cost the same. Is there a benefit to buying a particular size?
Difference in shank sizes...
Tags: None
IF a router accepts both sizes, get the 1/2. 1/2 are stonger, less prone to vibration, and the larger shaft allows for better grip in the collet.
For everyone that I know who have a choice, they would get the 1/2.
There are a few, very few bits that come in 1/4 only. And there are also some 1/4 bit sets that are made for miniature furniture and mini wood work projects that come in 1/4 only.
Outside of that, the 1/2 is the way to go.Last edited by leehljp; 02-10-2007, 05:53 PM.Hank Lee
Well said, Hank.
Nothing to add except to say, technically, the 1/2" shank has four times the metal of an equivalent 1/4" shank, so you can see why its more stable and stronger.
If I'm spinning a piece of sharpened metal at 30,000 rpm only inches from my hands, body, or head, I'll take all the shaft strength I can get.
1/2 for me every time.-John
-Henry BlakeComment
1/2" shank
i wish i had known better, i bought a 1/4" set with like 40 bits about a year and half ago for like $70 bucks! you can get a half decent set for about $90 with a 1/2" shank. i think, someone posted a link to it here a couple of months back.
as hank has said and loring reinforced, definately, go with the 1/2" shank! you will find that its money worth spending._________________________
omarComment
A good set of 1/4 bits has its uses. smaller 'laminate trimmer' routers use them. A couple imes I converted my RAS into an overarm router by using the included 1/4" collet chuck.
But 1/2" is the shank to get for any kind of serious routing.Comment
I agree with the replies that say that the 1/4 has its place. Trim routers are great and are much more handy in certain situations than the larger routers.
However, for all round basic routing, the 1/2 inch is the best.Hank Lee
LCHIEN
