Rare earth magnets/glue
  • p8ntblr
    • 921
    • So Cal
    • Craftsman 22114
    Where do I get rare earth magnets? In a plan I found off the web they use it to affix an auxilary table to the table saw? Also what type of adhesive do I use to adhere it to the wood? What type do I use to glue a T-Rack to wood?
    -Paul
  • Stytooner
    Roll Tide RIP Lee
    • 4301
    • Robertsdale, AL, USA.
    I would say use a two part epoxy of the appropriate type for the magnets. While that would work for the T-track too, I like to use short screws instead. It might require drilling and countersinking for the screws, but also affords recycling for use on an update jig or fixture should the need arise.
    Another problem with gluing them in is if they don't dry perfectly, what are you going to do about it? Not much.
    • Knottscott
      • 3815
      • Rochester, NY.
      • 2008 Shop Fox W1677
      Hartville Tool has them...Woodcraft might also.
      • linear
        • 612
        • DeSoto, KS, USA.
        I got some of the surplus magnets from K&J Magnetics and they are serious stuff. Good bang for the buck too. I believe I paid about 20 bucks shipped for 100 ZD2 magnets.
        The regular priced ones are even stronger. The higher the grade number,the stronger, so N40 is a stronger magnet than N35. However, you can stack them too--I like the discs because you can just drill your hole deeper and put in two instead of one for more pull.
        I've used super glue on mine so far.
        --Rob
        sigpic
        • Slik Geek
          • Dec 2006
          • 708
          • Lake County, Illinois
          • Ryobi BT-3000
          Two additional sources for rare earth magnets:
          www.leevalley.com
          www.digikey.com (part numbers 469-1000-ND thru 469-1007-ND)
          Prices on these magnets vary considerably between suppliers.
          Digi-Key caters to the electronics world. They generally ship same day.
          • Thom2
            • 1786
            • Stevens, PA, USA.
            • Craftsman 22124
            Let's not forget .... http://www.amazingmagnets.com/ .... their whiteboard magnets are AWESOME around the shop, and the prices are reasonable.
              • 22108
              1. eBay, search for magnets
              2. hot melt glue (foir magnets to wood)
              • radhak
                • 3061
                • Miramar, FL
                • Right Tilt 3HP Unisaw
                What is an appropriate usage (within woodworking, or in the house) for such magnets?
                I can see that the strength of the magnet can really scale up (14 lbs pull force for a tiny 1/2" dia, and this lonesome hook allows for 361 lbs of pull force?!!! I could hang all my tools and myself onto it.... !!)
                I thought a couple could be used for a shop-made magnetized feather-board, but too small a one would not be good enough, while too powerful would make it difficult to detach it.
                What use have you put a rare-earth-magnet to?
                - Aristotle
                • Kristofor
                  • 1331
                  • Twin Cities, MN
                  • Jet JTAS10 Cabinet Saw
                  Just one (probably too obvious) note... I'm not sure if you're a darksider, buit if you own a BTxxxx saw you won't be using magnets to attach anything to the table or the rails directly as those are aluminum. A piece of iron/steel could be put into one of the t-slots which would give good attachment strength for smaller magnets, but something bigger may need to be attached as the size/strength required increased.
                  Kristofor.
                  • THyman
                    • 315
                    • Atlanta, Georgia, USA
                    You can also get them at Rockler or maybe an Ace hardware as well.
                    War Eagle!
                    • jziegler
                      • 1149
                      • Salem, NJ, USA.
                      I got mine from Lee Valley as part of a larger order. I doubt I would place an order for just the one item.
                      I have used regular, 5 minute type epoxy. Drilled a matched hole with a forstener and epoxied into the hole.
                      Digikey is a good source for electronics and electronics related hardware, but they have a hefty $5 handling fee for all orders under $25. Unless you plan to order lots of magnets, or some other parts they carry, there are probably better options.
                        • 22108
                        they can hold fixtures on place on machines with steel fences and tables.
                        They can be used to couple things together (like someone used a pair to connect a micropositioner to a fence) where you need them to come apart under force or coersion.
                        Brio trains the wooden kids toys) use them to couple cars together - other good toy usage possible
                        People use them for cabinet door closers like a latch but don't physically have to touch and create wear.
                        • ChrisD
                          • 881
                          • CHICAGO, IL, USA.
                          Jigs are probably the most common application for magnets in the woodshop. Or holding your tools up on the wall.
                          Some folks incorporate cam levers into jigs to assist in prying it off the cast-iron surface.
                          Chris
                          • p8ntblr
                            • 921
                            • So Cal
                            • Craftsman 22114
                            I'm making a slider miter table. I'm going to put the magnets on the auxilary table to the right of the slider to catch the excess piece as I cut it. The magnets serve to hold the table in place.
                            -Paul
                            • Thom2
                              • 1786
                              • Stevens, PA, USA.
                              • Craftsman 22124
                              I have 3 of the wooden handled 'bench brushes' around my shop, I drilled holes in the backs and gorilla glued (2) 1/4" magnets in each of them. Now they stay at each station without having to search for a hook to hang them on.
                              This was my first experience adding seperate drops into the dust collection system that I had previously. (aka a broom and dustpan )
