Cut the miters the best you can, join the two pieces together temporarily and then run your saw back up thru the joint where they come together. i've done plywood like this and it can make a good and tight joint. You have to be careful with your set up so there is no binding and make sure the two pieces don't move at all.
If you had to cut a long miter how would you do it
An extra thought - silverfox is right that the walls aren't going to be perfect, so plan to modify the backsplash once the 45 is tight. Don't try to get the fit perfect on the 45 until the backsplash is scribed and trimmed as necessary.<font size=\"1\">\"We act as though comfort and luxury were the chief requirements of life, when all that we need to make us happy is something to be enthusiastic about.\" <i>Charles Kingsley</i></font id=\"size1\">Comment
Footer Ad
