Which way ????
  • gettools
    • Sep 2006
    • 161
    • Fort Worth, Texas
    Which way ????
    Hey yall,
    I read somewhere the proper way to cut , Is it finished side down with a table saw & up with a circular saw??? or do I have it backwards ??
    Mark
    Mark
    A chip on the sholder is a sign of wood further up !!!!
  • jerrye
    • 88
    • Raleigh, NC, USA.
    You have it backward. Easy way to remember: always have the teeth entering the good side, thus circ saw is good side down and table saw is good side up. Also use this rule with jigsaw. HTH
    Jerry
    When you think you've built it idiot-proof, they build a better idiot...
      Jigsaw blades also come with a tooth design to cut on the downward stroke, designed primarily for laminates, but can be used for other materials.
      A THING OF BEAUTY IS A JOY FOREVER - John Keats
        Jerry'es right. The way to remember is that the fuzzy side of the cut results form the teeth pulling fibers away from the unsupported trailing side of the wood. If you look at how the table saw blade turns, it cuts at the edge closes to you and the teeth enter from the top cutting through the wood and out the bottom. So the clean edge will be on the top.
        • gettools
          • Sep 2006
          • 161
          • Fort Worth, Texas
          Thanks for the information. I really do like this web sight & all the help that is here. I have just started my project. Book shelves for each side of my fire place. Merry Christmas
          Mark
          Mark
          • TheRic
            • Jun 2004
            • 1912
            • West Central Ohio
            Mark
            Remember to post pictures, so the rest of use can get ideals.
            Ric
