zctp
  • bigdaddyjohn
    • 129
    • Fort Wayne, IN.
    • Jet 10" Contractor
    zctp
    Edited this message because it sounded kind of stupid. I want to make a zctp. Not sure what material thickness to use. Not by the saw (bt3100) so I can't measure. Would like to pick up a piece of stock material that will fit. Don't have access to a planer yet, hopefully for Christmas....
    Thanks,
    bigdaddyjohn
  • scorrpio
    • 1566
    • Wayne, NJ, USA.
    I got a couple sheets of UHMW-PE, about 1/4" thick. The TP size is roughly 14"x3" - you'll want slightly longer than 14 for a snug fit.
    After cutting up the UHMW to size, I routed the rabbets for edges and recesses for those retaining screws in the back. Then, drilled and countersunk the mounting holes. All in all, made a batch of 8 ZCTPs in one go. They seem to work real well, and ZCTP is quite rigid.
    • Tom Miller
      • 2507
      • Twin Cities, MN
      I use 1/2" baltic birch plywood. I'd probably use 1/2" thickness if I was using solid stock, too. Off the top of my head, I can't think of any reason you couldn't use 3/4" thick stock if that's all you have around, and don't have a planer yet.
      Regards,
        • 22109
        Thanks,
        bigdaddyjohn
        Read the FAQ linked at the bottom of my signature line.
        There's been a multitude of materials used, from plastics and wood, mostly because they are easy to machine and stiff enough.
        You'll probably want someting 1/4 to 3/8 or maybe 1/2" thick and you need to be able to rabbet the edges to the right thickness using a router, or a dado blade or multiple passes of the standard TS blade if you have none of the above.
        If you go with 1/2" thick material beware of catching the blade when you go to cut the blade slot, read the warnings in the FAQ.
        • thestinker
          • Oct 2005
          • 613
          • Fort Worth, TX, USA.
          I made mine from one in the FAQ. I want to say they were .5 in poplar stock with rabbits milled in the edges to make it the same height as the table.
          Riley
