spiral bit? for speaker openings
  • gychang
    • 188
    • Sacramento, California
    • none
    Building speaker is my hobby, and I have a handheld router I use frequently. I have a straight bit but spiral bit has been recommended for mostly MDF and plywood work.
    Anyone have recommendation in under $50 range?
    thanks,
    gychang
    Check MLCS.
    • vaking
      • 1428
      • Montclair, NJ, USA.
      • Ryobi BT3100-1
      Spiral bit 1/4" diameter is usually under $20. I use Lee Valley and like it a lot. MLCS is ready to sell you a set of 3 bits (1/4", 3/8", 1/2") for $50 with free shipping.
      Alex V
      • gychang
        • 188
        • none
        thanks, Alex.
        gychang
          Rockler also has the spiral bits, I use their high speed steel bit for 1/4" mostly. Less likely to break. I believe our friend Holbren has them as well.
            if you order carbide bits, you can get them for $15-20 from the router bit specialty discounters.
            You might want to order two of the 1/4" spiral carbide bits = they're
            somewhat brittle and thin in crosssection, you may break one, I did.
            • Al Garay
              • 75
              • Seattle, WA, USA.
              If you don't have one, look for the Jasper circle jig which uses 1/4" bit.
              I recommend Infinity bits which are having an overstock sale:
              http://www.infinitytools.com/products.asp?dept=1307
              Look for 85-113 spiral upcut bit for $12.
              • gjat
                • 686
                • Valrico (Tampa), Florida.
                I bought my spiral bits from Holbren and have been happy. Get an up-spiral bit to help w/ dust removal. It's much faster and I feel I have better control than plowing through with a straight bit.
