In-Lay Glass?
  • mackmack
    • 106
    In-Lay Glass?
    I have a small wooden box(MDF actually). I want to in-lay some glass in small(1/2"-1") cut out circles(think of it looking like a block of swiss cheese). I want to make it so you can see the glass from the outside but the inside still maintains its smooth walls. How do I do that?
    I'm thinking that I need to create a lip around the inside of each circle to glue the glass in but I'm not to sure how to go about doing that and if I need any specific tools.
    I am good with the glass, cutting it and preparing it, I just need to know how to get the stuff to fit into the sides of the box flush.
    Thanks like always for any and all help!
    Before you assemble the box, cut the holes. Then use a rabetting bit around the holes. This will give the ledge for the glass.
    • gjat
      • 686
      • Valrico (Tampa), Florida.
      I'm lazier.
      I'd use 2 different sized forstner bits on the drill press. To keep the holes aligned, make an alignment jig to clamp in place. Or clamp, drill the smaller, change the bit to larger, drill.
      • Tequila
        • 684
        • King of Prussia, PA, USA.
        Originally posted by gjat
        I'm lazier.
        IF you're going to go that route, it's better to dtill the larger hole first. That way you'll still have the centering mark to align to when you go to drill through with the smaller bit.
        -Joe
        • niki
          • 566
          • Poland
          • EB PK255
          I think that it will be very difficult to cut circles of ½”~1” glass. If you can or have them or you can order them, go ahead with one of the above methods.
          If you cannot, I would cut (rout) a recess at the center of the board at the depth of the glass thickness, leaving ¼~1/2” at the edges, than drill the holes and glue a full piece of glass with CA (super glue).
          niki
          • gjat
            • 686
            Good point, nikki. I like your style. Practical and efficient.
            Gave me an idea to put some round veneer in-lays into some small boxes I'm making. How can I cut a number round veneer pieces that will fit exactly into the the whole. No, I do not own a router template kit.
