As promised - loose M&T video
  • ironhat
    • 2553
    Hey Jim, I went to the Woodsmith magazine site and didn't locate the pdf (I'm lame - I know). If you have it how 'bout sharing. I'm hoping that it will show a good clamping method since I don't own a Shopmate bench.
    Later,
    Chiz
    Blessings,
    Chiz
      Jim, that's the point of the multi-plunge setup. It removes the friction of trying to slide the edge guide along while cutting. Makes it much easier. Give it a try and let me know how it goes.
      • sinjams
        • 13
        • Wiarton Ontario
        • 3100
        Great Video Do not do amy mortise cuts yet but will keep in mind when I take the plung.
        Do I really need dial calapers?
        • ironhat
          • 2553
          Is this type of joint loose enough (and still strong at the same time) to make allowances for a slightly off positioning of either the M or the T? I've only regular M & T's on scrap and can't get the joint sufficiently perfect to have the rail and stile perfectly aligned on the face.
          Blessings,
          Chiz
            sinjams, My calipers are one of the most used tools in my shop. They are fairly inexpensive, and beyond useful. I found my set at big lots for about 15$, but you can get digital ones for about 30$. The dial ones take a little getting used to in terms of reading. The digitals are much easier in that respect.
            ironhat, with mortise and loose tenon, you don't have the alignment problems that you have with mortise and integral tenon. That's one of the biggest advantages. As you make 2 mortises, you can simply reference your guide off of the fronts of both pieces, and like a dowel the alignment will be spot on. You don't want the joint to be loose, as yellow glue doesn't gap with strength. For that you'd need epoxy, but you shouldn't run into that problem with this technique.
            • mcgrath4u
              • Jun 2004
              • 205
              • Livonia, Michigan, USA.
              • Sears (Orion Made) 22124
              Great video. Sorry if this is an obvious question, but what type of router bit do you use when doing this? Upcut spiral?
              Thanks,
              John T
                The video mentions a spiral cutter, but doesn't specify what type, sorry. I used a 1/4" high speed steel spiral upcut bit. I also use solid carbide ones, but they break more easily, though they last longer.
                I got the bit for 11$ at Rockler. I also have several from Holbren. You should use an upcut unless you are going for a through mortise, then you should use a downcut bit.
