My first attempt at some cabinet doors using the slot cutter bit that came with my Holbren bit set.
Cut a 1/4" slot into the inside each of the stiles and rails for a small plywood panel to sit. Cut four more small pieces of plywood to use as splines so they were the same thickness and used those to hold the stiles and rails together as well. Nice tight fit with all the parts so pretty happy with the results.
http://ssmith1627.myphotoalbum.com/v...d=152_5225_IMG
http://ssmith1627.myphotoalbum.com/v...d=152_5226_IMG
Two more cabinet doors and then I can get back to building the world's ugliest dollhouse for my niece.....haha.
Steve
Steve
