Filed rail nuts!
  • Salty
    • 690
    • Akron, Ohio
    Filed rail nuts!
    Did anyone else do this? I noticed that the edges that compress against the rail are a bit jagged so I filed them down and rubbed waxed paper on them before assembly. Seems to make the rails slide a bit easier.
  • lcm1947
    • 1490
    • Austin, Texas
    • BT 3100-1
    You know that's a good idea. They sure need something to make the rails slide easier - a lot easier too. Thanks for the idea.
    • Salty
      • 690
      • Akron, Ohio
      I think I'm going to take mine back off and polish the edges with some 600 grit wet-dry sandpaper. That should stop any dragging on the rails.
      May work on the SMT fence bolt too. That sticks a lot.
      • kmk
        • 415
        • .Portland, Oregon
        I'm going to try this idea! I need it!
        • Salty
          • 690
          • Akron, Ohio
          The 600 grit wet-dry sandpaper helped a bit more. They do slid easier.
          However, I must correct myself here and possibly appologize to the designers of this saw. I said earlier that "the edges that compress against the rail are a bit jagged", which is incorrect. The side that compresses againt the rail when the lock is engaged is the rounded side. The T-nuts cannot be put in backwards. But, whatever was causing it to drag is virtually gone now.
          Note: I also rubbed everything down with a piece of waxed paper. An article that I saw on the main page mentioned this and it is a great idea. Please someone remind me who that suggestion came from and give the credit due.
          Salty
          • kmk
            • 415
            • .Portland, Oregon
            I belive gmach5 mentions wax paper in his reply to new owner posts.
            • Salty
              • 690
              • Akron, Ohio
              Thank you.
              And thank you gmach5 for the tip!
