Hello Everyone
  • kolku
    Hello Everyone
    This is my first post on this forum. I have been lurking here since about Christmas. My lovely wife wanted to get me a table saw for Christmas. Her budjet was limited (I was actually looking at the grizzly 1023 saw), so I started shopping around for something affordable and ended up finding this place due to a reference from new yankee workshop I think. Someone on that site had posted saying they should talk about some tools that "normal" people can afford and gave the BT3 as an example. So long story short this forum/site sold me on the saw and we picked one up at HD yesterday for 249 + a $75 gift card. Came out to be just under 200 with tax. I haven't finished setting it up yet (we have a 5 month old who takes up a lot of our time), but hopefully tonight I'll have a chance to finish setting it up and actually cut something. Then all I need to do is find a project to work on :-)
    Btw... I already read all the very helpful advice on making sure I read the manual and setup everything properly.
    Have a wonderful day everyone!
    Josh
  • jhart
    • 1715
    Welcome to the forum Josh. Send pictures of your projects as you do them.
      Josh
      welcome, Josh!
      • BobSch
        • 4385
        Welcome to the asylum. Now, go paint the red line and start makin' some sawdust!
        Bob
        • Ken Weaver
          • 2417
          • Clemson, SC, USA
          • Rigid TS3650
          Welcome aboard Josh! Make sawdust, have fun, be safe!
          Ken Weaver
          Clemson, SC
          • Wood_workur
            • 1914
            • Ohio
            • Ryobi bt3100-1
            Welcome! Have fun, and be safe.
            Alex
            • Tom Hintz
              • 549
              • Concord, NC, USA.
              Welcome!
              Keep that manual where you can find it again for when you think the saw needs adjusting, as they eventually all do.
              Second, is make the wife something nice, that she wants. You are going to want more tools and showing her now how useful you can be helps!
              Tom Hintz
              NewWoodworker.com LLC
                Welcome to the group Josh. Be safe and enjoy the forum.
                • gmack5
                  • 1972
                  • Quapaw, Oklahoma, USA.
                  • Ryobi BT3000SX & BT3100
                  Welcome Josh,
                  Congratulations on the acquisition of your BT3100 and welcome to the "family".
                  One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the preceeding one, so you MUST keep them in sequence.
                  Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes. The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
                  entire saw.
                  Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
                  You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/ The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site). One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
                  This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea. One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
                  A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
                  Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
                  You might also want to check out the "FAQ" shown in the link below.
                  http://www.bt3central.com/forum/topi...TOPIC_ID=12490
                  It'll answer a lot of your questions.
                  George
                  • bigstick509
                    • 1227
                    • Macomb, MI, USA.
                    To the best forums on the net.
                    • kolku
                      Well I got the saw all put together once the little one fell asleep. I have not "tune" everything yet, however I did make a miter cut on a scrap 2x4 just to say I have "used it" [] Hopefully sometime this week or over the weekend I'll get it all setup the way it should be.
                        Welcome to the Asylum, Josh!
                          Congrats on both the 5 month old and the new toy (saw). If you treat it right, it'll do a lot of work for you for a good long time.
                          • monte
                            ***** Windbag
                            • 5242
                            • Paw Paw, MI, USA.
                            • GI 50-185M
                            Welcome to the group Josh. Enjoy your new saw.
                            Monte (another darksider)
                            • scorrpio
                              • 1566
                              • Wayne, NJ, USA.
                              Grats on the saw! Before any serious use, make sure to supply adequate dust collection. I got a Ridgid 12-gal shopvac connected to saw's back, it sucks off all the dust and small waste pieces that fall through the throat plate opening, keeping everything squeaky clean.
                              And be sure to wear eye and ear protection when using it, even if it is 'just one cut'.
