What is the best method for removing the sticky wax material that tool manufacts put on cast iron tables, steel blades, etc?
Removal of Anti-Rust Gunk
Tags: None
Jeff,
It looks like you picked up the Jet :-)
JoeEvery tool you own is broken, you just don't know it yet :-)Comment
Mineral spirits also works well.Monte (another darksider)
http://community.webshots.com/user/monte49002Comment
The "gunk" varies a bit from brand to brand, but I've had success with mineral spirits, kerosene, WD-40, and Simple Green....oh, and a whole lotta towels!
I've seen the cautions against using *anything* in the shop that contains silicons due to it's great ability at contaminating wood. I was curious about WD-40 and after briefly checking, it appears it contains none and is safe. In regards to contaminating wood, would any of the previously mentioned substances be safer to use than some of the others?
EdEd - South Alabama
Original \"Getting Started\" thread pertaining to my cabin: Shopping List for Remote Cabin Project
Direct link to the Cabin in the Swamp... construction website.Comment
I need to remove both items from different products. Sounds like the oily material is covered by other posts. Now I need to remove wax. Also, what material should I put back over the cast iron table? Are the wax type items that go on the table generally sold at HD, Lowes or HF?quote:Originally posted by DaveW
wax material, or the oily material? I think the manufacturers generally recommend kerosene.Comment
quote:Originally posted by Woodwerker
Jeff,
and got it about 80% put together late Saturday night.
What do you think of the fence? Looks awesome but store models have a hard time holding. I have attached rails and put fence together but I have not level wings and tightened rails. However I had to give the fence a try and it seemed like it had a hard time staying in place. I have not looked very far into it though. Any tips needed on final assembly of this product? Some of those frame and screws and dust cover screws were a tough reach for me!Comment
