Hello,
Fairly new to wood working and have a bt3100 + accessory kit + ryobi router..
I need to make this piece for a project I am working on which requires 4 channels 1/4" tall by 3/4" wide. Basically locations for screws to slide left to right. It's a bracket for a monitor (75mm VESA).
My question is how should I make the holes? My first attempt was to just use a drill and drill 3 1/4" holes next to one another.. Didn't work too well at all. I was thinking that I could use the router to make them, but wasn't sure. I would need to setup some type of stops because I wouldnt' be able to see what I was.. I'd also have to "drop down" onto the router unless I guess I drilled one hole first.. Then I'd need also purchase a router bit which was at least 3/4" since that is the thickness of the material I am working with...
I think my best bet might just be a drill press? Thanks for giving this newbie any advice..
-jr
-jr
LCHIEN
