new bt3100 owner
  • gimpy
    • Nov 2004
    • 197
    • Flagstaff, AZ.
    new bt3100 owner
    Well, finally pulled the plug and went to the Borg this afternoon and bought me one. LOML even went with me and even applied for the credit card for the 10% off[:0] suprisingly. Got it put together this evening and even turned it on. Sounded real good. I think I'm going to like it, but anything will be better than my old circular saw.
    Ever since I found this place and listened (read?) about the way everyone on here talks about the saw, I've been wanting one.
    Frank
    Frank, "Still the one"
  • monte
    ***** Windbag
    • 5242
    • Paw Paw, MI, USA.
    • GI 50-185M
    Welcome to the group Frank. Be safe and enjoy your new saw.
    Monte (another darksider)
      Welcome to the Asylum, Frank!
      • silverfox
        • 2863
        • Richland Center WI, USA.
        Welcome to the cult, Frank. I know you are going to have many years of fun and service from that saw. The out of the box thinking behind the building of the saw will amaze you with its simplicity and subsequent results. Let us know what you think after you fire a few pieces through it.
          Welcome to the forum Frank and hope you enjoy it. Going from a circular saw to a TS will be quiet a treat.
          • gmack5
            • 1972
            • Quapaw, Oklahoma, USA.
            • Ryobi BT3000SX & BT3100
            Welcome Frank,
            Congratulations on the acquisition of your BT3100 and welcome to the "family".
            One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the preceeding proceedure, so you MUST keep them in sequence.
            Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes. The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
            entire saw.
            Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
            You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/ The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site). One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
            This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea. One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
            A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
            Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
            George
            • kyle.w
              • 425
              • paw paw, mi, USA.
              • GI 50-185M
              i like my saw alot!!! and welcome!!
              • DUD
                • 3309
                • Jonesboro, Arkansas, USA.
                Welcome Frank, I've got the old model saw and have had it for years, the only conversion I've done is the Sharkguard. I know You will love Your new toy. Bill
                  Frank, Enjoy your saw and post some pictures! Glad you finally got one.
                  In case you didn't notice it, this is a real close group here and we always open our house to fellow members. Being that you are in Flagstaff, a place I don't get to often but love it as a vacation spot . . .
                  Just kidding you!
                  • gimpy
                    • Nov 2004
                    • 197
                    • Flagstaff, AZ.
                    Thx, all. As you can see, I've been a long time lurker here, but am new to woodworking. All I've actually built are a couple of speakers (currently building a 20 inch cubed sub woofer) out of mdf and a router table (out of plywood-top has not been added, yet)(sorry, don't have a camera for pics). It's actually been too cold last couple of days to go out to the garage and work. (bones are starting to age a little/don't hold the heat like they used to).
                    gmack, I did paint the line. And leehljp, you're welcome here anytime.
                    thx, again, Frank
