Bevel Cut Question
  • TheHinge
    • 32
    • Georgia, USA.
    Bevel Cut Question
    When I make a bevel cut, with the angle at 45, and this may be obvious, but I take the combo square and do a 45 angle down the thickness of the board. Then I cut on the waste side of that line? The left side of the blade touching the line (I know the blade is thin, but it has a little thickness). Is that how I should cut it?
    I was trying to make a box and I don't think I locked my angle so they all ended up at 44. Just throw them away? Or can I still use them? They look okay....
    Thanks everyone for answering all my questions.
  • Tom Miller
    • 2507
    • Twin Cities, MN
    By all means, recut them if you can. Salvaging your pieces after a bad cut is 90% of woodworking, if you ask me.
    Then, next time try checking your bevel angle with some scrap stock (scrap stock = good stock + bad cut).
    There are lots of good ways to check a 45 degree cut. One is to cut two pieces and see if they form a 90 degree angle, since 90 degree angles are easier to check.
    And concerning your first question: Yes, you absolutely need to take into account the thickness of the blade. One edge of the blade or the other should be lined up with your cut line.
    Thin kerf blades are 3/32" wide. Include that in your measurements as necessary.
    Regards,
      • 22108
      When marking and cutting you should always be aware of which side of the cut will be part of the finished work and which side will be waste.
      Maybe you'll use it later and it won't be truly waste but for the cut you are about to make you want the blade kerf to be on the waste side.
      It is a common practice to mark a series of XXX's on the waste side of a cut line you mark so there's no doubt about which side of the line you want the blade to be on.
      Do this and there'll be no confusion because if you don't everything will not fit together, you'll have a series of 3/32" mistakes that'll really add up the wrong way!
      Also 44° is not a good bevel, put two of these together and you'll have a 2° gap staring you in the face. Best to set up using good instruments and then make a test cut and confirm until you get high confidence in your ability to set up. Markings on machinery and even measuring devices can and often are wrong. The first thing to do is to learn which mearuring devices you can trust.
      • boblon
        • 727
        • Florida, USA.
        quote:The first thing to do is to learn which mearuring devices you can trust.
        Now there is some sage advice !
        BobL.
