Dumb question: Say I set the saw up with a router. But then I want to cut more wood. Do I have to take the router back off before I can use the saw again? My guess is, uh, yes.
Do I take the router off to saw?
It's very easy to remove with the 4 screws and only takes a minute. You won't loose your router settings either.Monte (another darksider)
http://community.webshots.com/user/monte49002 -
My router has been out of the table once since I mounted it. I just remove the bit and make sure the collet is below the table.Larry R. Rogers
http://community.webshots.com/user/splash54Comment
I'm with the others, just drop the bit below table height.Comment
Mine rarely comes off unless I need to move the rails to the left for a cut. Then I remove the acc table with the router in it.
I leave the smallest insert plate installed to help keep sawdust out of the router collet and make sure I blow it out good before installing a bit.Don, aka Pappy,
PlatoComment
Another suggestion, gleaned elsewhere: if you want to remove the bit but keep your same bit height setting, put a rubber O-ring at the bottom of the collet. If you make a point of always snugging the inserted bit down to the O-ring, you can remove the bit and replace it at the same elevation above the table.- David
“Be yourself; everyone else is already taken.” -- Oscar WildeComment
