Planers/Jointers with Plywood
  • maderawood
    • 8
    I'm new to woodworking and I have read that you should prepare your timber by jointing, planing and then ripping on the tablesaw to ensure you have accurate edges and flat faces.
    I have mainly built bookcases out of 3/4" hardwood plywood with hardwood edging. Does anyone prepare plywood with a jointer and planer or would that destroy the veneer face? I'm not sure what the smallest increments are on these tools but the exterior faces of these plywoods seem awfully thin. Any thoughts would be appreciated.
    Thanks.
  • Ing
    • Jun 2004
    • 45
    • Spring Hill, FL, USA.
    Can be done, but not a good idea. Not only will it tear out and destroy the face veneer, but plywood is loaded with glue that will quickly load up and destroy planer/jointer blades. While in theory you can take off any ammount, 1/64th is about the practical limit. If your plywood is warped or twisted, better to start off with new.
    • autiger1
      • 549
      • Tampa, Florida, USA.
      If you're trying to edge joint - I would do it with a router.
        • 22109
        I tried planing the face of plywood once. I would reduce my experience to a single word - "Don't".
        • DaveW
          • 415
          • So Cal.
          I do this with the router all the time, but not having a jointer, my question is - why not use the jointer? isn't it basically the same mechanics as the router? i.e., a spinning set of cutters? Or is it just a matter of cost? i.e., a new straight bit can be gotten from woodcraft for $5 when on sale?
          • Hoover
            • 1273
            • USA.
            You use a planer and a jointer on solid wood not plywood. Splinters will happen on plywood, the plies are laid up at 90 degree angles to each other. The cutters will catch the the thin plies, chips will fly and the wood will look like angry beavers attacked just before dawn!!
            No good deed goes unpunished
            • monte
              ***** Windbag
              • 5242
              • Paw Paw, MI, USA.
              • GI 50-185M
              The router bits are much cheaper than jointer knives.
              Monte (another darksider)
              • Tom Miller
                • 2507
                • Twin Cities, MN
                The purpose of a planer is to reduce the stock to the necessary and consistent thickness. You should not need to do this with ply.
                The difference between jointer and router for edge jointing is the difference between HSS and carbide.
                Edge jointing with a jointer will ruin your HSS blades pretty quickly. The glue lines can make noticeable nicks in the blades in just one pass.
                Carbide router bits will last longer for this purpose.
                I have straightened ply edges in preparation for ripping on a TS with a block plane. Worked OK.
                Regards,
                  Offhand I can't think of a reason why you'd need to edge-joint OR thickness-plane plywood.
                  Edge jointing is typically done when you're gluing up narrow boards to make a larger panel. With plywood, you'd just cut the panel to size. Assuming this was done accurately, using a good blade, the edge will be plenty straight enough for applying either edging or a face frame.
                  Thickness planing, as has been noted, is neither necessary nor possible with hardwood plywood. The finished face veneers are paper thin. Even a random-orbit sander will eat through them in a heartbeat; a thickness planer would utterly destroy them.
                  • steve_ma
                    • 45
                    Well said. You dont edge join ply or reduce its thickness. These are things you do with solid hardwood.....
                    Normally, anyway....
                    But, I like the original question. I dont have a jointer, and I dont really know what a "planar" is. A jointer, as I understand it, has a series of knives that can shave a board down to given thickness...maybe something like a 1/8 or 1/16'th at a time.
                    So if I have a rough board, I can "plane" it down to some thickness, butg how do I get a square edge?
                    • Hoover
                      • 1273
                      • USA.
                      In a nutshell don't get these two separate tools confused, they have different uses.
                      A planer puts a smooth surface on a board. This tool is useful even if you buy surfaced lumber, and is required if you buy rough-cut lumber. When used in combination with a jointer, a planer will not only smooth a surface, but will make that surface parallel to the opposite surface that you previously flattened on the jointer. In other words, a planer and jointer together can remove warp from boards
                      The jointer is used to make one surface parallel and one edge flat.
