Dining room table for grandkids
  • BadeMillsap
    • 868
    • Bulverde, Texas, USA.
    • Grizzly G1023SL
    My grandkid's mom bought a new house and asked me to build a dining room table for her and my grandkids.
    I took an Ann White drawing made some modifications and put this together. The main table is old reclaimed shiplap and the rest is just yellow pine I resized to meet my plan.
    Sent from my SM-G973U using Tapatalk
    Bade Millsap
    Bulverde, Texas
    => Bade's Personal Web Log
    => Bade's Lutherie Web Log
  • radhak
    • 3061
    • Miramar, FL
    • Right Tilt 3HP Unisaw
    Whoa! That is such a grand piece of furniture! Looks sturdy too!
    What's the finish?
    - Aristotle
    • BadeMillsap
      • 868
      • Grizzly G1023SL
      Originally posted by radhak
      What's the finish?
      Thank you! The finish is some American oak poly finish I had left over and then 3 coats of water based satin poly I wiped on. Nothing really special on the finish but I used a water based sealer to prevent or lessen blotching on the pine.
      Sent from my SM-T113 using Tapatalk
      Bade Millsap
      Bulverde, Texas
      • jussi
        • 2162
        Looks great. That’s a unique support at the base.
          • 2812
          Really a very nice table. Your grandkids will enjoy sitting down to family occasions with a table made 'just for them' by their grandfather!
            That top reminds me of an oak desk I made when I was overseas. Looked identical in color and shape to the top picture except it was only 3ft front to back. I did run into one problem - humidity swings caused just enough contraction and expansion to cause gaps and a few cracks in the boards on the inside boards.
            • BadeMillsap
              • 868
              • Grizzly G1023SL
              Thank you all.
              The base structure was a re-engineering of the original plan because I wanted to be able to remove the top for easier transport and getting through doors.
              As far as splitting concern on the top, I glued and screwed those boards to a piece of 3/8 particle board for stability. I have used this technique several times with success so far. It does add significant weight. This top is 64"x40" which is as close as I could get to the golden ratio.
              Bade Millsap
              Bulverde, Texas
                Great job and a good way to recycle old wood!
