Wine Cart-The Story
    Wine Cart-The Story
    Last summer, a wine cart project was posted in a Canadian publication.
    I thought it would be fun so I gathered up the lumber and set to work. The following pictures run through some of the more significant steps. The top was 2x6 cedar, planed to 1 1/4 and and the middle and bottom shelves were from 5/4 fence boards planed to 7/8's. The rails are 1/2" copper pipe.
    Gluing the top section
    To cut the copper pipe, I built a jig to work with a precision saw and a pipe cutting blade.
    Pipe cutting jig
    (Continued)
    Tops sanded and edges rounded over
    Pipe and legs cut to size. Legs have bored out to receive pipe.
    Dry fit before finishing
    (Continued)
      To finish the cart, I sanded to 220 and applied a 50-50 blo/ms blend and let it cure for a week. Then sanded at 220 again and applied Circa 1850 Tung And Teak oil. Once dry I sanded at 220 the reapplied the Tung and Teak oil. After this coat dried, I buffed with extra fine steel wool and applied 2 coats of poly, buffing with steel wool in between coats.
      Finished cart
      Thanks for looking. Now I need to get back to pens
      • sailor55330
        • Jan 2010
        • 494
        I really like that finish and it looks great on the cedar. Thank you for sharing the details of the finish work.
          Looks great Rich!! :-) Did you end up putting anything on the copper?
          • Turaj
            • 1019
            • Toronto, Ontario, Canada.
            • BT3000 (1998)
            Looks great Richard! Don't remember (from the original article) but is there any castor under the cart? I like the finish too!
            Turaj (in Toronto)
              • 22053
              Finished cart
              Back to pens? Looks like you're headed to the deck (although it must still be Winter in Canada, maybe this is for next summer).
              Seriously looks great.
              • big tim
                • 546
                • Scarborough, Toronto,Canada
                • SawStop PCS
                Nicely done, Richard!
                I like Circa 1850 products. Made by Swing Paints in Montreal.
                I have used their Antique Danish Oil and liked it very much as well.
                They have an interactive website where you can ask questions and they always respond very quickly, at least to my querries.
                Again very nice wine cart, congratulations.
                Tim
                  Great looking cart, Richard. The finish really makes the tones in the cedar pop!
                  How about a wide shot of the whole thing?
                    Thanks for all the kid words friends. The copper was sprayed with a few light coats of clear Krylon. There are 2" castors under the skirt supported by 1" blocks from the base shelf. And one wider shot as requested.
                      That really looks great, Richard. It's a sight for sore eyes. Nice job.
                      • jking
                        • 972
                        • Des Moines, IA.
                        It looks very nice. Do you plan to use the bottom shelf for anything (storage?), or will it stay empty?
                          Yep........
                          • cranbrook2
                            • 168
                            • Belgrave ont., Canada.
                            • KING INDUSTRIAL KC10-CCX
                            Beautiful work Richard !!
                            John in Belgrave ont.
                            www.extremebirdhouse.com
                            http://www.facebook.com/groups/112698715866/
                              Thank you again guys.
