thanks for the new pics. very nicely executed design.
Honey do project!
That is a nice design. It's not quite like a fixed shelf but better than the typical shelf that floats on pins or brackets. If you fool around with the sagulator, you'll see that for a given shelf geometry, fixed shelves sag about 25% less than fixed shelves.
I wish I could do that for some leaning shelves I'm building but cutting simple dadoes at 7 degrees off perpendicular is already giving me fits and sweats.
Nice job! I've made a couple similar cabinets based upon a plan from Woodsmith. It does not have the fixed shelf but has a face frame. It is also a little narrower and shorter. Shelves are supported by pins and are working fine for my daughter and me so far.
JimComment
Thanks again for all the kind words! I will post another picture or two as soon as it is painted (probably late Spring). Meanwhile I have to get to work on few projects for the shop itself.
Turaj (in Toronto)
She couldn't tell the difference between the escape pod, and the bathroom. We had to go back for her.........................Twice.Comment
Nicely done, Turaj.
I like that style for shelf supports. When I made a china hutch several years ago (oh my it was in 2006? time flies!) I used that style for the shelf supports in the lower half. I had remembered a project that Norm did on NYW.Last edited by Brian G; 01-14-2012, 09:45 AM.BrianComment
Thanks Brian, I wonder if your project was where I saw that support style for the first time... When I made a china hutch several years ago (oh my it was in 2006? time flies!) I used that style for the shelf supports in the lower half...
if so, then thanks! Either way, I am happy that I tried it and am pleased with the results.
Turaj (in Toronto)
