Been a while...spinning wheel
    It has been a long time since I've been to this forum, I just have not had time honestly, for the forum or the shop, sadly.
    I did get in there today to make this for my company, they are doing a game at the Christmas party that needed a nice way to determine chance. The plan is to paint it with white board paint so that it can be used for a variety of things in the future.
    It was fun to do a quick project, I've been slowly building cabinets for our kitchen for about 2 years. It's sad how little shop time you have when you have 2 jobs going and a 3 year old.
    Hey Keith, good to see you're still around. I can empathize about the work and kids thing except I've got one job and 2 kids under 2. Why else would either of us be up posting this early?
    I like practical projects like these. How is the wheel mounted to the base so it's not all wobbly when spun? What is the material for the spring mechanism? Sheet metal? I could see myself building one of these someday,
    Paul
      Sometimes those are needed just to get some relaxation time. Looks like this one turned out well.
      • jking
        • 972
        • Des Moines, IA.
        It's good to see you back.
          • 8807
          Great to hear from you again! Great looking project you have there!
            Thanks all, good to be in the shop occasionally, wish it were more often.
            Paul, the wheel has a 1/4" shelf pin sleeve glued into the center and is attached to a lag bolt, the kind with a smooth bit and threads only towards the end. The bolt is run through the main post which is 2 3/4" ply bits laminated together and pegged, then pocket screwed to the base and reinforced.
            The main post has a small section of 1/4" ply glued on additionally as a spacer where the wheel is mounted, then a fender washer, then the wheel, a fender washer again (not shown in this photo) and then 2 1/4" nuts. Snug up the first one by hand, put some lock tight on the thread then put on the 2nd nut snug by hand, then 2 wrenches and tighten them against each other. It runs pretty darn true.
            The flapper at the bottom is simply a couple of pieces of plastic from a Qdoba take out pan glued together and then clamped there into place. The right hand side is glued/screwed into position and the left hand side floats and is bolted to the right creating a clamp.
            It has a nice satisfying click click click when spun. I delivered it today to work and spent most of the day answering questions, everyone is really excited about it.
            • wardprobst
              • 681
              • Wichita Falls, TX, USA.
              • Craftsman 22811
              Keith,
              Good to see you again, I can certainly empathize with you on time for the forum. As you can see from my post count, I mostly lurk but I've really enjoyed your posts over the years.
              DP
              www.wardprobst.com
                Turned out well Keith. Post everyone once in awhile to keep in touch
