Portable 1.5HP DC with easy-empty Thien intake
  • Chris_B
    • 216
    • Cupertino, CA
    I borrowed (stole?) ideas from a bunch of places for this project, but thought I would post this since I have not previously seen a portable DC with an easy-to-empty can. Overall, this thing truly sucks!!
    The slide-out drawer is a recycled 12 gallon shop-vac base. Big enough to run for hours, but small enough that it is easy to empty.
    My previous DC was a 1 HP Steel City, and this is a *huge* functional upgrade with only a small increase in footprint. I park this DC near my tools, and move the 4" flex to whatever station is in use. This is not as convenient as a fixed installation, but is far, far better than dual shop-vacs!
    I had originally planned to install a large Clear-Vue cyclone, but the realities of life in a garage shop made a fixed installation not feasible. Half the time I am working in the driveway, which is a long, long way from my planned DC installation.
    Fortunately I think this thing is powerful enough to serve as a fixed DC source if I ever decide to permanently exile our cars from the garage.
    I know that the Thien separator is not a "real" cyclone, but so far the only time that I've gotten *any* debris in the plastic bag under the Wynn filter has been while testing it as a yard-waste collector (which overwhelms the Thien slot). Otherwise the bag is completely empty.
    The Thien intake is constructed from MDF slices. Fortunately a colleague suggested 'lightweight' MDF, otherwise I would probably have a hernia! Now I just have to find a use for all these MDF pieces that look like comic strip text-bubbles.
    For more details, there are a few more photos at this link.
  • toolguy1000
    • Mar 2009
    • 1142
    • westchester cnty, ny
    congratulations on a very nice modification. appears to be well thought and neatly executed. but what were you referring to as "lightweight" MDF? i only know the stuff from the box stores and the 3/4" 4x8 sheets are hardly lightweight.
    • Chris_B
      • 216
      • Cupertino, CA
      Thank you!
      Some lumber stores (not HD or Lowe's) carry a lighter-density MDF material. It is a little bit more expensive than the regular stuff, but the weight is much closer to plywood. IOW, it is light*er*, but hardly light. Regular MDF seems to be impregnated with lead.
      Apparently one of the trade-offs with the lighter-weight MDF is that it tears out and sags more easily than regular MDF. Neither of these issues was a concern in this application.
      • Chris_B
        • 216
        • Cupertino, CA
        FYI: Comparison of "lightweight" & standard MDF
        Here is a recent price-list from a lumber yard with a variety of sheet materials. While the absolute prices probably vary considerably by region, the relative pricing should be pretty close. In this case, "lightweight" MDF is 16% ($5) more per 3/4" sheet, and about 1/2 the cost of shop-grade birch plywood.
        The weight reduction is about 30%, and the strength reduction is closer to 40+%. See here and here.
        For applications requiring strength or sag resistance, I think most folks typically use plywood (and/or fastener inserts), so the lighter MDF variant should be generally useful. It is certainly easier to handle!
          if its significantly (30% would qualify in my book) less dense then can they still call it Medium Density Fiberboard (MDF) or is it now light density Fiberboard (LDF)?
          • Chris_B
            • 216
            • Cupertino, CA
            I also wondered about this. "Lighter" MDF certainly stretches the definition, but I think "LDF" = particle board, and "HDF" = hardboard (/Masonite). This stuff definitely machines and behaves much more like standard MDF than particle board. The only way I can tell the difference is by the weight.
            Think of it like 'Light' Ice Cream. Some of the brands get awfully close to "Ice Milk."
              Sweet! Isn't it nice to have a project that really sucks and that's a good thing?!?!?!
              Was this your own design or was it made from plans? Either way, nice job.
              • Chris_B
                • 216
                • Cupertino, CA
                Thank you! Yes, I am getting a lot of mileage (and sometimes confused looks) out of variations on "this sucks."
                This was my own design, but I got inspiration and ideas from a bunch of other posts (particularly on Phil Thien's forum).
                  How many slices are in your Thien intake?
                  Looks nice. I have been thinking of trying something like this on my 1hp Delta DC. I use it in one location and it will remove the debris pretty well from everything except the planner. Sometimes the table saw 4 inch flex hose fills up too. Probably when I have more than one gate open at a time. I also use a Wynn filter cartridge and find it get dirty fairly frequently. I am hoping something like this would help that too. I also like the idea of a smaller container on a slide out. I had been thinking of trying to find a drum that fit and I can but only from McMaster Carr and I am a bit afraid of their shipping costs for something like a large drum.
                  • Chris_B
                    • 216
                    • Cupertino, CA
                    13 total, including the top (with the intake hole) and bottom (with the slot). So the curved section is 11 x 3/4" MDF slices. This is actually one more than I planned, but I made one extra slice in case I screwed-up, and decided to simply include that in the stack as well.
                    For a bin, consider searching CL for a cheap shop-vac, or if you have a freecycle in your area post a 'wanted' for a shop-vac with a dead motor. I considered a small trash can, but could not find any strong enough to handle the vacuum - and the cost was more than I paid for the shop-vac.
                    • Rand
                      • 492
                      • Vancouver, WA, USA.
                      Pretty ingenious!
                      Nice job.
                      Rand
                      • Sid
                        • Apr 2004
                        • 139
                        • Bloomington, IL, USA.
                        • Craftsman 22124
                        Very nice!
                        It looks like you could have saved a fair amount of weight by cutting holes in at least three of the corners in the 11 center slices of MDF.
                        Sid
                        • Chris_B
                          • 216
                          • Cupertino, CA
                          Originally posted by Sid
                          Very nice!
                          Sid
                          Thank you!
                          Yes, that is a good idea. It would have been fairly easy to jigsaw holes in the three corners, particularly since no precision is needed.
