Chess Table
  • reddog552
    • Dec 2006
    • 245
    • Belleville Il.
    • Bt3000
    Chess Table
    Just finnished. This was made from old beat up craftsman blanket chest (Fine Pine)Mom made the ceramic chess pcs.. I have app. 100 squares left over, U woulnt believe how hard it was to cut 64 pcs.the same exact size. Played with different setups for hours to get them right. Finally made a sliding table with stops.
    The bitterness of poor quality lingers long after the sweetness of low cost is forgotten!
  • klefkow
    • 17
    Chess board
    A little late for you but this will help anyone else making a chess board.
    http://www.metacafe.com/watch/463464...uick_easy_way/
    • reddog552
      • Dec 2006
      • 245
      • Belleville Il.
      • Bt3000
      Duh
      That was easy
        • 22109
        the classic way of making a chssboard is to rip 8 lengths of alternating light and dark; the same consistent width should be achievable with a good table saw and featherboards.
        Then join (edge glue) them in into a board with alternating light and dark strips 8 wide.
        Then rip the cross direction to get strips of light/dark squares the same rip setting used before.
        Then flip every other strip end for end arriving at a checkerboard pattern. Join them edge to edge (glue-up again) and you get a perfect chessboard matching squares fits perfectly.
        If you want small contrast strips between the squares then you can picture ripping them and laminating them between the L&D strips.
        P.S. Oh, shudda looked at the video Klefow posted first... that's the exact same method i described.
        • radhak
          • 3061
          • Miramar, FL
          • Right Tilt 3HP Unisaw
          That's a lovely board, reddog! how did you get the dark colors?
          And did you say your mom made the pieces? How does she do that ??!!
          - Aristotle
          • reddog552
            • Dec 2006
            • 245
            • Belleville Il.
            • Bt3000
            table
            The stains were Golden oak & Black walnut. Mom made the pieces In ceramics then fired them red & black
              Very, very nice. A chess board is still one of "someday projects" for me.
              • phrog
                • Jul 2005
                • 1796
                • Chattanooga, TN, USA.
                Great work reddog. Really nice board. Your Mom did a great job also.
                Richard
                Richard
                  Very nice Reddog... wouldn't be interested in coming over and installing a parquet floor in my entrance-way would you....? Your mom did good on the ceramic chess set also. Although I don't find time to play anymore.. an old girl-friend from down in Austrailia made me a cerarmic set back in the early 70's which is quite nice. The bad news is none of my downfall lumber would fit in her kiln.
                  • GPA61
                    • 712
                    • Rancho Cucamonga, CA
                    • BT 3100 & JET JWTS
                    Great work.
                    Claudio
                      Very nice.
                      • jhart
                        • 1715
                        Great looking board and chess set. Chessboard has been on my to do list for years. Still haven't gotten around to doing it!!
                          That hearkens me back to my high school shop days. My son still has the chessboard I made using this method...
                          • Alex Franke
                            • Feb 2007
                            • 2641
                            • Chapel Hill, NC
                            If you have a band saw and you're short on wood, you can use my shortcut: Rip 2 lengths, edge glue them, resaw into 4, edge-glue again, then cross-cut. It comes out beautifully every time! (Lots of details and photos here: http://plans.thefrankes.com/Tutorial...d/Default.aspx)
                            • footprintsinconc
                              • 1759
                              • Roseville (Sacramento), CA
                              looks real nice. the ceramic pieces are very beautiful as well.
                              omar
