Wondow Cornices
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    Wow. thanks for all the nice comments!
    Originally posted by eezlock
    What did you use to hang them with on the wall? . . .
    I thought of using the old style wooden window screen hangers. The type where one part is afixed to the wall and the other part is attached to the cornice board in the upper corners and you lift the unit up and slide down
    and drop onto to the fixed portion and lock them in place.
    See, I should have posted *before* I hung them. That sounds like a lot easier than what I did -- which was basically a couple of L brackets, but practically impossible to do without help. They're really light, so there's only two screws holding each one up at this point.
    I ended up attaching the brackets to the wall first, then getting help to hold up the other end while I drove the screw into the cornice. I was only 1/4" plywood, so it was helpful to brace it along its length with a hardwood cutoff and a couple of spring clamps.
    Here are a couple of pictures. It looks pretty ugly from the back, but it's all covered by by the curtains so you'd have to be really nosy to notice the ugliness.
ID:	783228 Click image for larger version
