Simple Tape Holder
  • scmhogg
    • 1839
    • Simi Valley, CA, USA.
    Simple Tape Holder
    This is almost too simple to post. But, I had to think about it. So. . .
    I have a small shop and every square foot is occupied. I used to keep masking tape, duct tape, etc. in a drawer. It was a mess.
    I decided to hang a holder behind the 4' light fixture over my bench. Using only stuff I had on hand I made my tape holder.
    I had a piece of 2" ID PVC, some 1/4" threaded rod, nuts & washers, and a knob. I cut 3/4" Birch ply plugs with a fly cutter.
    I hung it under the cabinet, behind the flourescent fixture, with plumber's tape and screws. The knob is to allow the adding of new tape.
    Works fine and I have half a drawer to fill.
    Steve
    Simple idea, good execution. don't look like the vertical support is stiff enough so you can peel tape off any of the rolls w/o taking it off first. Just for storage, not use?
    • footprintsinconc
      • 1759
      • Roseville (Sacramento), CA
      neat idea of storage.
      i too was going to ask how does it fair when you try to use the tape while it is on the storage roll?
      omar
      • scmhogg
        • 1839
        The copper plumbers tape is surprisingly rigid. Each side is attached to to the cabinet with two screws through a 3" "EL'. I do have to steady the roll with my other hand with the Gorilla Tape. I'd be afraid I would pull the entire cabinet down with that stuff. It sure does stick. The others pull off without torquing the holder.
        One thing I didn't mention--I bought some "transfer tape" from LV. It is super thin double stick tape. All that remains is a very thin layer of rubber cement. I stuck the brackets to the underside of the cabinet and drilled and screwed them with the tape in place. It was a real aid in a difficult place to work, upside down and behind something.
        http://www.leevalley.com/wood/page.a...at=1,110,43466
        Steve
          Great idea.
            That is a good idea and I also like the way you have the washers, nuts and bolts labeled. I need to separate mine that way.
              Simple, but very effective. I'm glad you chose to post that (I just may have to do one!).
              • steve-norrell
                • 1001
                • The Great Land - Alaska
                What do you do when you need the tape at some distance from the 'dispenser'? Dismantle the holder?
                Regards, Steve
                • Brian in Dawson Creek
                  • Jul 2006
                  • 128
                  • Dawson Creek B.C. Canada
                  • Delta Cabinet Saw
                  I like your idea but may I say … you are way too organized, I mean I like your tape dispenser but your washers, nuts, and bolts all in separate trays?
                  I have much more efficient method that you … they are all in one big bag, problem is, it can take forever to find what I’m looking for and when I do find it I can’t remember what I needed it for.
                  Nicely Done
                  Brian
                  • Anna
                    • 728
                    • CA, USA.
                    That is a great idea. But I'll have to agree with Brian. You're giving us disorganized small-shop users a bad name. Not to mention big time envy.
                    My nuts and bolts are in little piles all over the shop. When I need one, I go over to HD and buy more. It takes less time than trying to hunt down which pile holds what.
                    • RodKirby
                      • 3136
                      • Mao Shan TSC-10RAS
                      Just for Anna
                      Downunder ... 1" = 25.4mm
