Cube in a Cube
  • Popeye
    • 1848
    • Woodbine, Ga
    • Grizzly 1023SL
    Cube in a Cube
    This was in the September issue of American Woodworker. It was just too neat and off the wall not to try out. I even invested in an expensive chunk of 3 X 3 Cherry at Woodcraft
    Pat
  • jackellis
    • 2638
    • Tahoe City, CA, USA.
    That is pretty interesting. Nicely executed, too.
      Wow!
      • jwaterdawg
        • 656
        • Washington, NC USA
        • JET
        Nicely done. I was thinking of trying that myself when I saw it in the mag.
        Have you tried a cube in a cube in a cube? Seems like the procedure could be carried out progressively provided one is careful with the drilling procedure.
        • radhak
          • 3061
          • Miramar, FL
          • Right Tilt 3HP Unisaw
          Wow! Wizardry!
          Too good for me to even add to my 'project list' - maybe I should buy it from you and claim I made it !
          Not having seen that issue, how is it done? Just a gist, not the whole procedure.
          I am assuming the back does not have a hinged door...
          - Aristotle
          • os1kne
            • 901
            • Atlanta, GA
            Very nice!! I saw that in the magazine and I may give it a try. The magazine made it seem relatively easy. How difficult was it to make?
            • Hoyden
              • Jan 2005
              • 122
              • Twin Falls, ID, USA.
              yep me too. Nice job.
              PawPaw
              • Russianwolf
                • 3152
                • Martinsburg, WV, USA.
                • One of them there Toy saws
                very nice.
                I'm thinking that depending on the depth of cut needed, you could do this with a router and eliminate the spur points on the captured cube.
                Lakota's Dad
                • bthere
                  • 462
                  • Alpharetta, GA
                  That is a pretty cool effect. It's amazing the sort of things that people can come up with.
                  • ironhat
                    • 2553
                    That gave me a smile. Neat!
                    Blessings,
                    Chiz
                      Very nice.
                      • Popeye
                        • 1848
                        • Woodbine, Ga
                        • Grizzly 1023SL
                        [quote=radhak;284022]Wow! Wizardry!
                        Thank you and .... Thom and I were talking about a cube in a cube in a cube. Might be something to play with.
                        The general gist of it is this. Start with a 3 x 3 cube. Mark one face corner to corner.(X) Drill that face to a depth of 1/16" with a 2" forstner bit just to get the hole started for the set up. Mark the intersection of the hole and the "X" Set the depth stop just short of this mark. Drill the end grain sides first. (stuff is hard to drill) then the other 4 faces. Essential sneak up on the inner cube but don't drill it free. Get close then cut it..... trust me on this one. I was doing four of these. Now the fourth one is a stand for two of the others Pat
                          [quote=Popeye;284144]
                          Originally posted by radhak
                          Wow! Wizardry!
                          Is that small cube completely trapped?
                          I suppose there's absolutely no reason you can't do 2x2 cube with a 1.3125" (1-5/16) forstner...
                          or any other size.
                          I'm guessing the 3:2 ratio is pleasing to the eye...?
                          • Popeye
                            • 1848
                            • Woodbine, Ga
                            • Grizzly 1023SL
                            [quote=LCHIEN;284147]
                            or any other size.
                            Yep, it's trapped but watching people try and figure out how to get it out is the fun part. And yes, any size cube and forstner would do. Just one of those mindless fun projects to kill an hour or so. Pat
                              That is pretty neat.
