Router Table/Cabinet
  • Duff
    • 164
    • San Antonio, TX
    • Enco 12" RT
    Fence looks like it reads Craftsman Professional... I haven't seen that one anywhere. looks solid!
    Enco 12" RT table saw(with router table currently added to right wing), Central Machinary 6" jointer, Delta 16" (17-900) drill press, Ridgid 14" bandsaw, Jet bench top Mortising machine, Porter Cable 6901 series routers (2) and a wide variety of Ryobi 18v tools.
      That fence was on closeout a little over a year ago at $22. They were quite popular (then, not precloseout), and you used to see them on the bay. (haven't seen, or looked in a while)
      • footprintsinconc
        • 1759
        • Roseville (Sacramento), CA
        Awesome!
        my god, that is one beautiful table! very nicely built and that fence sure does look really sturdy. where did you get it from?
        i notice you didnt put a slot in front of the router hole paralell to the fence for sliding a guide/jig that would hold your piece while routing?
        regards,
        omar
        • GPA61
          • 712
          • Rancho Cucamonga, CA
          • BT 3100 & JET JWTS
          Thank you guys for all your nice compliments. Also, thank you for all the advice on the finish for the top.
          Tim, I guess your question has been answered. It is a Craftsman Professional. I purchased one on closeout and never used it so I sold it to one of the forum members. So when I decided to build this table I had to go find another one. I got this one on e-bay.
          Also got the plate on e-bay. This one is 3/8x11x13 aluminum. No,it does not have any crown on it, it has a sag in the middle (bowl). Not the quality plate I was looking for. But I needed a large plate to accommodate the size of the router, the handles aren't removable. It was actually a little twisted and I had it straightened at work.
          About a miter gauge slot, I guess one can be cut if I ever need one.
          Thanks again. I'm going to go finish the top.
          Claudio
          • Jeffrey Schronce
            • 3822
            • York, PA, USA.
            • 22124
            Very nice. Agree with poly. If using wipe on I might use a few more coats, maybe 5-6 since the build is about half of straight poly.
            • wareagle
              • 66
              Great Job!
              Really nice work.
                Morning Claudio...
                Well done Claudio... about everything in my shop is home-brewed and built from mostly scrap and left-overs. And it has served me well I may add as you don't have to compromise on someone's else design that is not exactly as "you" want it.
                If I could have made the suggestion before you added the tracks, etc... I would have suggested to use formica or laminate (or whatever they call it now.. ) on the top and coat everything else in 3 coats of poly. Since the issue has already been decided.. I will join the others that suggested 3 coats of un-cut poly.
                Again... nice job!
                • JWS
                  #23
                  Excellent work Claudio!!!
                  John
