Lumber rack and cull-bin cull bin
  • Brian G
    • Jun 2003
    • 993
    • Bloomington, Minnesota.
    • G0899
    (edited on 4/27/2008 to re-insert pictures)
    I got tired of tripping over, moving around, and rummaging through my unorganized pile of stock. I also needed some place to put my "cull" pieces and good cutoffs. First, the lumber rack (2/3rds complete):
    I borrowed heavily from dlminehart's rack that he posted. This rack is in my basement shop, along the "old" foundation wall that's now the interior of the new half of the basement. The "curb" of the drop from the old floor level to the new floor level gave a nice platform for sheet good storage. Plus, it doesn't impede on floor space, because the lumber rack is flush with the curb. The 2x4 studs are anchor-sleeved to the wall, four per stud. That's probably overkill. . . but I didn't want to risk collapse. The spacing between studs (23" OC) is a little wider than I'd like, because a 6' board rests just on-center of the outer two horizontal supports in a four-support stretch. I thought I planned for a 21" OC spacing, but I must have made a change somewhere along the way that I can't remember. Oh well.
    I did make a few changes to Dave's excellent system. I used 3/4" EMT conduit. That required use of a 15/16" spade bit at 5-degrees for the horizontal supports. I had to use a spade bit because that's all I could find in that size. A 29/32" bit would have been perfect, because there is a gap in a 15/16" hole. I used two wraps of aluminum tape to get a snug fit; I couldn't find any of the curtain rod stuff that Dave used.
    Here is the complete version.
    I can fit 8 full sheets of 3/4" plywood in the sheet good section, plus a various amounts of other remnant thicknesses in the left-most lower section. Those vertical padded conduit supports are loose-fit so that I can pull them out easily. I'm pleased with the result, and I'd be happy to provide more details if anybody wants them.
    Finally, I needed a place to put my "cull" pieces that are too good to throw away, or too useful to burn. So, I made the following entirely out of HD cull rack material. It's a mix of 1/2", 3/4", and 1/4" MDF, with a 1/4" BC plywood back. I didn't follow a plan. . I just made it up as I went along. It's difficult to tell in the photo, but there are 6 "bays" in my cull-bin cull bin.
    Last edited by Brian G; 04-27-2008, 07:20 PM. Reason: fixed pictures that were lost during forum upgrade
    Brian
  • Ken Weaver
    • 2417
    • Clemson, SC, USA
    • Rigid TS3650
    Nice Brian!
    Ken Weaver
    Clemson, SC
    • messmaker
      • 1495
      • RICHMOND, KY, USA.
      • Ridgid 2424
      I saw a cull rack just like yours with a rack for sheet goods on the back. The whole number was on wheels. It is my next project. You gave me the motivation. Great job.
        Good way to save space and just look at all that wood.
        • jethro
          • 1081
          • Newark, DE, USA.
          Well done, Brian! What did you use for the padding on the outside of the conduits?
          jethro.
          <font size=\"1\">Never attempt to teach a pig to sing; it wastes your time and annoys the pig. -- <i>Heinlein</i>
          http://www.jeffriegner.com</font id=\"size1\">
          • SteveR
            • 494
            • USA.
            Organization at its best...fine job. Bet it feels great.
            • Tundra_Man
              • 1589
              • Sioux Falls, SD, USA.
              I'm looking at all that wood and drooling! Nice work!
              Terry
              • dlminehart
                • 1829
                • San Jose, CA, USA.
                Nice job, Brian! Wish I'd had the foundation "curb" to work with on my exterior wall version. Gives me an idea, though, to put some pressure-treated 4x4s on the ground, with a couple diagonally-drilled holes toward their backs through which I can drive some 2' lengths of rebar. At the front, I could copy your vertical conduit supports.
                You're probably wise playing it safe with the 3/4" conduit, though I've yet to have any trouble with the 1/2" stuff.
                - David
                • rickd
                  • 422
                  great job, brian!! i've been thinking about building a cullbin for some months now and after seeing how 'neat' your wood was stored compared to my 'pile of scraps', i finally got motivated and spent this morning building a cullbin similar to yours - just finished it.
                  I put wheels on mine because i may have to move it from time to time because of space requirements. other than that it is very similar to yours.
                  now, i just have to sort out my 'scraps' to fill my new cullbin.
                  rick doyle
                  Rick's Woodworking Website
                  • Brian G
                    • Jun 2003
                    • 993
                    • G0899
                    Thanks for the comments.
                    jethro, the padding is foam pipe insulation. I don't know what the correct term for it is, but it has a slit lenghtwise and you use it over copper pipe that tends to want to attract condensation. HD sells it in 6' lengths in the plumbing dept., but I bought it packaged in 4, 36" lengths at Menard's. I got twice as much in the bags for the same price.
                    Steve, yes, it does feel great to get that stuff organized. I'm not what I'd consider a neat freak, but I can't stand having to step around and over stuff. Getting the wood stored has freed up floor space for the workbench I'm currently building. The cull bin was a welcome addition, although I still have stuff that wouldn't fit.
                    David, if I recall correctly, you use the thicker, galvanized 1/2". I confess that I went with the 3/4" EMT because it was cheaper. That front 1 x 3 is intended to keep half-width, full length sheets in place. They tend to flop forward, so I'd do a re-design on that part. I'm basically wasting 2" of space there, although I think with some eye bolts and bungees I could fashion a retainer.
                    Brian
                    • monte
                      ***** Windbag
                      • 5242
                      • Paw Paw, MI, USA.
                      • GI 50-185M
                      Nice Brian. I need to follow the example.
                      Monte (another darksider)
                      • GPA61
                        • 712
                        • Rancho Cucamonga, CA
                        • BT 3100 & JET JWTS
                        Looks like a good solution for the problem I have, lack of
                        organization. Great job, Brian. [8D]
                        Claudio
                        Claudio
                        • lcm1947
                          • 1490
                          • Austin, Texas
                          • BT 3100-1
                          Thanks ever so much for the idea. Excellent job and man is that going to be handy.
