Jewlery Box
    Originally posted by DonHo
    "Are the trays removable? Is the bottom of the tray fabric covered or bare wood (possibly walnut as well)?" Yes, the top tray is removable and the "dividers" are removable from both trays. The box and tray are lined with a brown colored "fake" suede.
    "what kind of joinery did you use between the legs and the box?"
    The legs are just attached with titebond glue. I've made a few other boxes with legs like this and have had no problems with the legs coming off.
    DonHo
    But, what kind of joint then at the corners of the box? Is it a mitered box with the legs applied? I'm not saying it is coming apart, just trying to learn how you did it so I can try it, too.
    • DonHo
      • 1098
      • Shawnee, OK, USA.
      "what kind of joint then at the corners of the box? Is it a mitered box with the legs applied? I"
      OH, my bad. The other boxes I've made with this type leg had mitered corners, because I wanted the sides and back level with the top and the front sitting under the top, I made this box using rebates on the front and back. I could have made it with mitered corners but couldn't figure out how to easily make the top 3/4" of each side not mitered and the rest of the joint mitered(the sides are exposed when the lid is raised. I thought of making miters then gluing 3'4" mitered blocks on top of the sides but since the joints are covered by the legs, I figured the rebates wouldn't show.
      DonHo
      Don
        Beautiful work.
        • Alex Franke
          • Feb 2007
          • 2641
          • Chapel Hill, NC
          Wow, that's a pretty dramatic box. Very nice, indeed.
          How long did you hang on to that walnut before you figured out what to use it for?
          • Wood_workur
            • 1914
            • Ohio
            • Ryobi bt3100-1
            that is very nice. I love the maple you used.
            Alex
            • Brian in Dawson Creek
              • Jul 2006
              • 128
              • Dawson Creek B.C. Canada
              • Delta Cabinet Saw
              I’d give my eye teeth for a chunk of wood like that! You did it proud.
              Brian
