last minute gift: walnut box
  • linear
    • 612
    • DeSoto, KS, USA.
    I had to shoot one at the buzzer, but I believe I may have hit the bucket.
    This box is made from a walnut cutoff from the cull bin at the local yard. I planed the resawn board to just about 3/8, then cut 4 slots in it with a 3/8" router bit on the table:
    1: rabbet for the top
    2: rabbet for the bottom
    3: inside lip of the lid
    4: outside lip of the box.
    Slot #4 is on the face of the board that is the outside of the box, the others are all inside. Slots 3 and 4 are separated from each other by about a bandsaw kerf, so that when the box is done, I can saw the lid off and have the lips done and ready.
    With my board slotted, I measured length and from there established my dimensions. I had a 29" length, so I decided on 10x4" more or less. I quickly crosscut the pieces on the BT3100, then made a rabbet in the sides of the end pieces.
    then I dry fit everything, checked for square, made adjustments, and cut my top and bottom to fit. I used a bit of figured walnut for the top panel. My bottom was a little thinner than the 3/8" rabbet, and my top was a little thicker, but no problem--the roundover bit equalized things nicely at the end for the lid, and the bottom is protected from scratches by being slightly inset.
    Then it was glueup time, and once things were dry, I sawed off the lid on the bandsaw. I was generous with the space between slots 3 and 4, so I had a bit of cleanup, which took a minute with a utility knife. I fine-tuned the lid fit a little with a sanding block, and put a little roundover on the inner lip.
    Then I whipped on some Tru-Oil and took these pics. I put in about 3 hours total, and the next one will get done in half that time.
    I like this project because there are almost no critical dimensions (make sure you have top and bottom stock wide enough). I didn't measure anything except to determine how much I could use out of my stock to set my box size.
    This is going to my neighbor, who has given me enormous assistance over the last few years.
    --Rob
    sigpic
    • 22086
    simple and elegant. Good work for 3 hours.
      That's a 3-pointer for sure.
        Very nice box and good to see someone uses what someone else considers cull or scrap.
        Regards...
        • jackellis
          • 2638
          • Tahoe City, CA, USA.
          The box is beautiful and I can see making something similar out of scraps I have from resawing that too thin for other projects but almost exactly the right thickness for this. Only problem is, I'm a bit too dense to figure out how you determined the box dimensions from the size of your scrap piece.
          • linear
            • 612
            • DeSoto, KS, USA.
            Jack, I measured the length (29"), divided by two (14-1/2") and decided how I wanted to split that between the front and sides, leaving myself a half-inch or so wiggle room for kerf widths. Plus, being cull, these had some unusable wood toward the end (I think I accounted for that in my 29"). Since I knew the stuff I had on hand for top and bottom was only 3-1/2" wide, I knew I better not exceed that width.
            --Rob
            sigpic
              Nicely done! I 'm sure it weill be well receiverd.
                Very nice looking box.
                  Nice box, Rob.
                  • GPA61
                    • 712
                    • Rancho Cucamonga, CA
                    • BT 3100 & JET JWTS
                    Excellent work Rob.
                    Claudio
                      Very nice.
                      • GeekMom
                        • 752
                        • Bonney Lake, WA.
                        • Shopsmith Mark V
                        Beautiful! And only 3 hours? Not in my workshop!
                        Karen
                        • linear
                          • 612
                          • DeSoto, KS, USA.
                          Originally posted by GeekMom
                          Not in my workshop!
                          Thanks, Karen, but that's one of the beautiful things about this technique--it should be called "speed box" probably.
                          I talked about nothing needing to be precise, and that's pretty true. But if you have precisely set the depth of your rabbets (set with the router fence position) to match your stock thickness (whatever that is) then you end up with very little sanding to be done.
                          Here's three more I made yesterday and had time left over to see a movie with the kids and make dinner. The bottom one illustrates what happens if you don't se the rabbet depth to the thickness of the stock like I suggest. Easily fixed, but will slow you down if you don't have a belt sander.
                          I used Tru-Oil again but thinned it naphtha for an even faster finish. The top two have just two coats of that mix, but I will probably throw on some more coats. These have a chamfer on the lid instead of a roundover like the earlier one.
                          --Rob
                          sigpic
                          • boblon
                            • 727
                            • Florida, USA.
                            Those are pretty nice boxes and a neat way to make some quick boxes.
                            I'm gonna have to find some 'scrap' and give this method a shot. Would be perfect for throwing together a box to house the real gift or whatever.
                            Thanks for sharing.
                            BobL>
                            • Wood_workur
                              • 1914
                              • Ohio
                              • Ryobi bt3100-1
                              beautifuly simple
                              Alex
