bloodwood gift box
  • linear
    • 612
    • DeSoto, KS, USA.
    bloodwood gift box
    Don't tell my wife, this is her Christmas present.
    Sort of a bandsaw box, but instead of drawers that slide out, the trays pivot on two axles made from 1/8" brass rod. It's small, it would fit inside a 4" diameter circle. I used some narrow 4/4 bloodwood stock. I was originally planning to template route the trays, but the small size confounded me. I took everything to its final shape by hand, so there's a good deal of imprecision. The lids are solid, and I put the shape into them with a microplane and card scraper. The base is a bookmatched glueup of a resawn piece of my thin bloodwood stock. The grain pattern was a sort of happy discovery--the grain was mostly straight as an arrow in my stock.
    This shows the completed box with the contoured lids. I was sick of making rectangles, but I haven't got a lathe to make round things, so this is what I came up with. It's sort of inspired by a piece I saw in the Klockit catalog. But I made my own templates and worked out the design myself to take advantage of my narrow stock.
    My version allows both halves of the lid to open. Through [s]dumb luck[/s] inspired design, the halves do not interfere with each other, so each tray is individually accessible.
    Opening this up reveals more trays beneath...
    Yet more trays...
    --Rob
    sigpic
  • linear
    • 612
    • DeSoto, KS, USA.
    And at the bottom there's a solid base piece about 3/8" thick that maintains the spacing between the axles. Like I said, I was stunned to get some heart shaped grain figure in an otherwise straight-grained board.
    Bloodwood takes a finish superbly. Using synthetic steel wool I was able to get a **** of a lustre on the wood with no product applied. I put on several coats of Tru-Oil to get to the final finish shown. In my lacquer spray tests, the surface didn't quite gloss this much so I stuck with what I had used previously.
    Bottoms of the trays were resawn off like a bandsaw box, and they are about 1/16" thick, which gave me some tearout issues when I cut them to shape. Backer board while doing the final shape would have helped.
    One more close up to show the grain in the bloodwood. I didn't attempt to fill grain.
    I really enjoy working with bloodwood. I did not run into any sensitivity problems, and the smell of the stuff is wonderful, sort of like suntan lotion or coconut cream.
    --Rob
    sigpic
      That's a real nice piece of craftsmanship, Rob. I'm sure that will make the missus very happy, which makes you happy.
      What is the finish, it looks great.
      Ken
      • linear
        • 612
        • DeSoto, KS, USA.
        Ken, thank you, it's Birchwood-Casey Tru-Oil, which I learned about from Tundra Man and have been a fan of since. The only thing not to like about it is the price.
        --Rob
        sigpic
        • TheRic
          • Jun 2004
          • 1912
          • West Central Ohio
          Looks BEAUTIFUL!!!! I can not imagine her not liking it.
          Ric
          • Popeye
            • 1848
            • Woodbine, Ga
            • Grizzly 1023SL
            BEAUTIFUL . Pat
              Very nice.
              • niki
                • 566
                • Poland
                • EB PK255
                Mama miya, that's a present from the HEART
                Beautifully made
                niki
                • Mrs. Wallnut
                  Bandsaw Box Momma
                  • 1566
                  Your wife will love that. Absolutely BEAUTIFUL work.
                  • GeekMom
                    • 752
                    • Bonney Lake, WA.
                    • Shopsmith Mark V
                    Your wife will love this! What a beautiful gift!
                    Karen
                    • Turaj
                      • 1019
                      • Toronto, Ontario, Canada.
                      • BT3000 (1998)
                      WOW! That is just beautiful!! Great work!
                      Turaj (in Toronto)
                        That is beautiful work.
                        • WoodButcher26
                          • 167
                          • Dayton, OH
                          That's really cool looking, I love the design. Great work!
                          Measure it with a micrometer...
                          Mark it with a crayon...
                          Cut it with a chain saw!
                          Wood Butcher
                            That is beautiful work. I was looking at the pictures before reading the writeup and thinking you'd planned it well to cut it just right so the drawers didn't interfere with each other. Personally, I wouldn't have known it was 'dumb luck' without you telling me.
                            • linear
                              • 612
                              • DeSoto, KS, USA.
                              On the drawer interference, I did test it out at full scale with my MDF templates. the trays did interfere, but only slightly, so that when you opened the left-hand sidea little, you could then open the right. It was a close thing, so I decided not to recalculate my axle positions. Then in the final shaping, I wound up decreasing the size of everything from the template somewhat in the process of fine-tuning the fit. In the process I cured my slight interference.
                              Thanks everyone for looking. I know based on the feedback from the ladies that I'm on the right track gift-wise. I am attempting a little subterfuge; I packed the piece up in a camera box that's loaded down heavily with MDF scrap, so as to give a false impression of the size and weight of the gift.
                              --Rob
                              sigpic
