Industrial Sewing Counter, Pt 1 (27 pics)
    After finally getting a digital camera, late last year, the extreme heat of Summer 2006 reduced my time in the workshop to almost nil, giving me no finished projects to photograph. But here is one project from this fall, presented in photo essay form.
    The job involved building an L-shaped countertop for a friend's sewing business. She was on a tight budget, which meant that only the most inexpensive of materials could be used: ordinary framing lumber, OSB, hardboard, drywall screws.
    Which further meant that I wouldn't be doing fine woodworking, per se, but something more like glorified rough carpentry. Even so, I decided to approach the project's construction in much the same way I would build a piece of furniture. That my friend's budget limited us to humble materials didn't mean I shouldn't try to give her a finished product that was as well-built and as attractive as I could possibly make it under the circumstances.
    I began as I always do, by making a number of crude sketches to explore how the counter might be built, and just generally letting my brain cells work on the design, almost subconciously. The main dilemma I fought from the beginning was that building with 2x4s usually results in assemblies that are crude and bulky, with inelegant joinery. After much deliberation, I decided to invest the time required to mill the rough 2x4s four-square, and to employ mortise and tenon joinery for most of the connections.
    The following series of pictures documents the workshop phase of prefabricating the Industrial Sewing Counter, step by step, from start to finish. I'll show you the on-site final assembly phase of the project in another thread.
                  This concludes the portion of the project that I was able to prefabricate in my workshop. For the on-site final assembly phase, please see the thread entitled, "Industrial Sewing Counter, Pt 2." Thanks very much for looking!
                  • onedash
                    • Mar 2005
                    • 1013
                    • Craftsman 22124
                    How did your planer hold up after all those 2X4's?
                    What kind of camera????
                    • niki
                      • 566
                      • Poland
                      • EB PK255
                      If I compare it to me, you are Factory...
                      And you have very nice machines
                      Glad that the pics worked in full size
                      Looking forward for part 2
                      niki
                      • Tom Miller
                        • 2507
                        • Twin Cities, MN
                        Great write-up, Larry! I applaud your attention to detail, even when, as you say, the materials are not exactly furniture-grade. In the end, your finished product isn't going to look anything like 2x4 construction. I'm sure your friend knows she's getting a pretty good deal.
                        I'm looking forward to more pics from your shop, too, now that you've got the digital camera!
                        Regards,
                          That is what I call a detailed explanation. Great pics Larry.
                          • TheRic
                            • Jun 2004
                            • 1912
                            • West Central Ohio
                            Looking great!!! Your pictures and explanations pretty much says it all. Can't wait to see part 2 and the finished project!!
                            Ric
                              After looking at the part 2 pictures, I didn't (though I should have) realize how much prefab work into that. Awesome job Larry.
