It’s Finished!!!!!
  • kwgeorge
    • 1419
    • Alvin, TX, USA.
    It’s Finished!!!!!
    Well, almost anyway. I still need to apply some kind of finish to it and I am kind of leaning towards tung oil or lacquer at the moment. In any case what had happened is that the brass for the lever cap came in and I just could not stand it. So hack, hack, cough I called in sick and stayed home to work on the plane. I made the lever cap out of 3/8” thick by 2” wide piece of 12” brass. First I drew it on the computer then I used a ball mill to create the groove where the lever cap meets the cross rod. I drilled and threaded it for 1/4-20 and shaped it. I made the locking bolt out of 3/4” brass rod then threaded it, shaped it and knurled it. I then inlayed a piece of Red Heart into it. The blade that I bought was a Lie-Nielsen 3/8” block plane blade with bevel up so I had to completely grind the bevel off and start over grinding for a 25 degree bevel down. I was concerned that the blade may not be hardened where the new bevel was but no worries after 3 hours of sharpening I can assure you it is!
    Sorry about the darkness in some pictures, since the brass refects so much I took the pictures without a flash. I am going to retake them outside this weekend if the weather holds up. Anyway, on with the pics!
    You know, I guess what is really important about this piece is it is a tool after all so I bet your saying, “but, does it work?”
    You BETCHA!!!!!!
    Thanks for having a look and what do you think for my first try at a plane? I am thinking about sending photos to FWW for the anual tool issue but I have not decided yet.
  • Scot
    • 34
    • Ottawa, Canada
    • Ryobi
    Beautiful. A work of art.
    Art
    • Derrick
      • Jul 2005
      • 206
      • Kansas City
      WOW! That is beautiful!! I want one of those
      • gerti
        • 2233
        • Minnetonka, MN, USA.
        • BT3100 "Frankensaw"
        What Scot said...
        • Turaj
          • 1019
          • Toronto, Ontario, Canada.
          • BT3000 (1998)
          Beautiful piece of work!!!
          Turaj (in Toronto)
          • lcm1947
            • 1490
            • Austin, Texas
            • BT 3100-1
            The prettiest one I've ever seen. Truely a beautiful tool! And it works? Good Lord that is something.
            • scmhogg
              • 1839
              • Simi Valley, CA, USA.
              Ken,
              That is really a beautiful plane. I said before that you could give Bridge-City a run for their money.
              And, it works!!
              Steve
              • ddamoore
                • Jun 2003
                • 225
                • Oklahoma City, OK, USA.
                • Craftsman (Ridgid 3612 Clone)
                Ditto that
                Dennis
                "Everybody is ignorant, only on different subjects" - Will Rogers
                • Cody.h
                  • 113
                  • Lubbock, Texas, USA.
                  Man that is just beautiful...you certainly should send into FWW....but you better be careful cause you might find you have to quit your job to go full time making woodworking tools...that'd be just awful wouldn't it!!
                  The truth is just the truth.
                  • RodKirby
                    • 3136
                    • Mao Shan TSC-10RAS
                    Beautiful
                    Just begging for about 10 coats of Tung oil?
                    Downunder ... 1" = 25.4mm
                    • warrenp
                      • 124
                      • Kentucky, USA.
                      Wow
                      That is a work of art. Beautiful.
                      • Tom Miller
                        • 2507
                        • Twin Cities, MN
                        Originally posted by kwgeorge
                        ...I bet your saying, “but, does it work?”
                        Actually, I hadn't gotten past "HOLY CR@P!"
                        That's just amazing on multiple levels, Ken!
                        Regards,
                        • Ken Weaver
                          • 2417
                          • Clemson, SC, USA
                          • Rigid TS3650
                          What everyone else has said Ken, be proud!
                          Ken Weaver
                          Clemson, SC
                            Beautiful! Excellent work!
                            • Jaden
                              • 202
                              • Trenton, MI
                              A functional and beautiful work of art.......
                              "I am so hip I have difficulty seeing over my pelvis." - Zaphod Beeblebrox
