Depth Gauges
  • scmhogg
    • 1839
    • Simi Valley, CA, USA.
    Depth Gauges
    I made these depth gauges from a plan in an old Wood Magazine. The woods are Mahogany, Tulip and Cocobolo. I cut the brass on the BT sandwiched between two pieces of plywood. I finished them with a couple of coats of Danish Oil, a couple of coats of shellac, [Zinsser’s French Polish] and a couple of coats of Renaissance Wax.
    Steve
    Those are very nice. They look like show pieces.
      beautiful, Steve.
        Beautiful work, Steve.
        • RodKirby
          • 3136
          • Mao Shan TSC-10RAS
          Very nice!
          Downunder ... 1" = 25.4mm
            OOOOH I want one! Nicely done. There is just something about a wooden tool for a wood worker.
              • 8781
              Nice looking! Simple too! Gotta make one, or two . . .
              I can never have too many depth guages. There are so many uses for them. I am an unorganized person but always put my 4 depth guages in a drawer and forget where they are. I need about 10!
              • Randy
                • Jun 2005
                • 73
                • Tifton, GA, USA.
                Very Nicely Done!
                • monte
                  ***** Windbag
                  • 5242
                  • Paw Paw, MI, USA.
                  • GI 50-185M
                  Very nice work!
                  Monte (another darksider)
                  • BobSch
                    • 4385
                    Beautiful work. Almost too beautiful to use.
                    Bob
                    • Tundra_Man
                      • 1589
                      • Sioux Falls, SD, USA.
                      Heirlooms for sure!
                      Terry
                        Very nice.
                        • gmack5
                          • 1972
                          • Quapaw, Oklahoma, USA.
                          • Ryobi BT3000SX & BT3100
                          Darn nice looking Depth Guages there, Steve!
                          Kinda makes me envious (just a little bit).
                          George
                            • 22028
                            These mechanisms (the main part of digital calipers) are now on selling for $10. This one on eBay looks to the the same or very similar to the HF digital calipers.
                            Someone willing to make a inverted "U" measuring frame from a 4" square of plywood and attache to the "T" will have a zero-settable digital depth gage. The "T" arms are attached to the readout unit and the scale slides up and down from the unit.
                            Attach the U as I described, lower the scale to the table top (so its touching at all three points), and zero the readout. You can now read + values as height to .001" and minus values as depth of grooves and rabbtets. You can also read hole depth of larger holes or small holes if you make a narrow probe attachment.
                            I have one, just need to "get around to it".
                            http://cgi.ebay.com/ws/eBayISAPI.dll...MakeTrack=true
                            Just thought to jog someone's mind...
