BT3 Mobile Cabinet
  • JTimmons
    • 690
    • Denver, CO.
    BT3 Mobile Cabinet
    Finally, after almost a year I got it done. Still have to seal it and line the drawers, but the main construction is done.
    It's the same height as my work bench so that I can use it as a out feed table.
    -- Johnny Carson
    Shaweet!
    • DaveW
      • 415
      • So Cal.
      Very nice - couple of questions for you -
      1) Is the bottom a torsion box, or is it a 2x4 frame with some 2x4s going from side-to-side inside that frame?
      2) how thick is the sheet above the box/frame?
      I've been mulling a base like this, and I'm just curious about the structural strengths/differences between a setup like yours vs a setup where the bottom is a torsion box, which is the entire length from side-to-side and the casters are under the torsion box.
      3) How do you get the base top to line up with the table saw top?
        Best thing I can say about it, Jock...
        Very Kirbyesque!
        • axio
          • 459
          • Castro Valley, CA, USA.
          Pappy's right... that's a fine piece of work there...
          • dlminehart
            • 1829
            • San Jose, CA, USA.
            I notice that the drawers under the saw are different heights than elsewhere. Is there a reason(s) for that? Does the shallow drawer just below the saw serve as access to removing sawdust not trapped by the dust collection system?
            The bench looks nice, too!
            - David
              That is very nice and you did a great job on it.
              • JTimmons
                • 690
                • Denver, CO.
                Dave's questions:
                I kind of copied the base from the Best Ever Workshops mag on page 61. It's a 2 x 3 frame underneath actually (I took off the round overs on the 2 x 4's). They run the length of the cabinet one on the front and back then one in the middle.
                The sheet above the frame is 3/4" MDF.
                I built the mobile base first, then built the carcus that the BT sits on, attached everything and measured from the top of the BT to the top of the mobile base to get the height I needed for the extension cabinet. It's not exact it's about a 1/32" off (lower) than the BT top. I finished the top w/ laminate on 3/4" MDF.
                dlminehart's question:
                Right, the thin drawer below the saw is for dust. The very top of the carcus that the BT sits on has a hole cut out to allow the dust to fall into the drawer.
                -- Johnny Carson
                • JTimmons
                  • 690
                  • Denver, CO.
                  Very Kirbyesque!
                  Wow, I did something Kirbyesque!!! That's a first for me, thanks a bunch.
                  -- Johnny Carson
                    I feel that I should say more than very nice but my old brain won't come up with anything better.
                    • Jim-Iowa
                      • Mar 2005
                      • 769
                      • Colfax, Iowa, USA.
                      nicely done!! I like it!
                      Sanity is just a one trick pony. Being a bit Crazy is a wide open field of opportunity!
                      • monte
                        ***** Windbag
                        • 5242
                        • Paw Paw, MI, USA.
                        • GI 50-185M
                        I agree with Pappy's reply.
                        Very Kirbyesque!
                        Great work!
                        Monte (another darksider)
                        • MURPHY-D
                          • 62
                          • San Antonio, New Mexico, USA.
                          I also agree with Pappy's reply, you can't get any better than that.
                          "Very Kirbyesque"
                          Don
                          \"One of our 50 is missing\"
                          • DonHo
                            • 1098
                            • Shawnee, OK, USA.
                            Very nice!!
                            DonHo
                            Don
                              I have to go with along with Pappy too. That is sweet.
