Locking lever for router table Bt3 clone
  • Pops Bees
    Handtools only
    • Jul 2021
    • 3
    • Chesapeake, Va.
    • Sears 315.228110 Bt3000 clone
    Does anyone know of a suitable replacement or have a spare they are willing to part with? Saved the saw from a trip to the recycling center and trying to get it all working correctly. It will be used to make bee hive accessories. Any help is greatly appreciated.
    the parts you are looking for are one of the T-nuts 11, and the knob and bracket 14,4 and 13.
    It shouldn't be really hard to make any of these with common hardware and simple operations.
    The t-nut 11 goes in the front facing slot of the rear rail. and is probably tapped for 10-24 or 1/4-20 thread and is easily made from a piece of 1/8" thick aluminum drilled and tapped.
    the knob thread matches the thread of the T-nut - knobs of this sort can be found in hardware stores small parts bins. My Ace Hardware usually has a good selection better stocked than Lowes or HD
    The bracket can probably be made of wood if you look at and measure what needs to clamp it.
    Click image for larger version  Name:	router table rear lock parts.JPG Views:	0 Size:	35.3 KB ID:	844590
    The illustration is from the router mounting kit instruction manual.
    • Pops Bees
      Handtools only
      • Jul 2021
      • 3
      • Chesapeake, Va.
      Sorry should have been more precise. The lever that locks the router table to the saw rail is what is broken. Part 102 in the parts illustration. The actual part number is 969175-002
        Do you mean the front locking lever on the router /Aux table?
        Yes, I see, that's part #102.
          • 2812
          Pops, you say it is broken, but do you have the parts, broken pieces, bolt, etc. ? Or are you missing everything?
ID:	844598 Click image for larger version
ID:	844599 Click image for larger version
          Here are three photos of my assembly, in case you're missing everything. The parts list will give you detail on assembly order.
            If you have the bolts and just the lever is broken, I think you could easily fashion a wood replacement... the forces are not so strong as to require metal.
            • Pops Bees
              Handtools only
              • Jul 2021
              • 3
              • Chesapeake, Va.
              I got it working. Machine screw and a old 5.56 mm rifle case. It had locked up from rust and corrosion. It was broken off when I picked up the saw. It was on the way to the dump if I didn't take it.
                Looks sharp!
                  • 2812
                  Well that will certainly do it. Good thinking.
                  Keep that brass polished
                  • Pops Bees
                    Pops Bees commented
                    Currently the shiniest thing on the saw. It was in sad shape bad arbor bearings, NO shims on motor carrier, no blade guard, broken miter holder, rust on steel parts and corrosion on the aluminum bits in hind sight I probably shouldn't have messed with it.
                    My free saw has cost me about $200.00 bucks.
