BT3000 shims
  • Healey
    • Mar 2014
    • 6
    • New Hampshire
    BT3000 shims
    I'm new to the site. I wish I'd found it years ago.
    I'm sure this has been discussed before, but I did a search and couldn't find anything. Are the 90 degree shims, Ryobi part #3, available anywhere? If not, has anyone ever made them from brass.
    Thanks
  • Clock Maker
    • Dec 2013
    • 21
    Assuming those are the elevation shims I got mine from ereplacementparts.com
    • Healey
      • Mar 2014
      • 6
      • New Hampshire
      Shims
      Thanks, but they are listed as obsolete, not available.
        Sears parts had them last I heard.
        • niswanger
          • Mar 2014
          • 9
          • Round Rock, TX
          I think Sears may be out too: http://www.searspartsdirect.com/part...dMod=&keyId=86
          -Roy
          • tfischer
            • 2349
            This vendor claims to have 16. No experience with them, just found via Google
            http://witmermotorservice.com/?produ...bi-formed-shim
              • 22085
              some guys have said they easily bent their own from brass stock available at hardware stores... Don't recall the exact posts but it was within the last year, probably 6 months so I'd look in the BT3 discussions.
              They should still be available for sale, too. I bought a spare set some years back so Murphy says I will never have to use them.
              • Healey
                • Mar 2014
                • 6
                • New Hampshire
                Thanks to Tfischer: I just ordered a pair from the site at your link. $8 for the pair of shims, but an egregious $12 for shipping. Oh well, at least I'll have a pair.
                I straightened out the set I currently have, and contact cemented them in place, but don't know how long they'll hold up.
                Thanks again.
                • TheNewGuy
                  • Mar 2014
                  • 6
                  • Dallas, TX
                  I can confirm that DIY shims work great!
                  I just got a small sheet of stainless steel (.008") from my local hobby shop and cut/bent a replacement. It went in great and after a little PTFE dry lube the blade will now raise/lower with zero effort!
                  The stock I got measures the same as the original shim but feels less sturdy. I think it may be coated with something and have a thinner steel "core". I suspect the DIY ones will wear out sooner but I got enough stock to make several shims for > $2 so I'll be happy to make new ones when the time comes.
                  Unfortunately when I got everything back together the motor no longer turns on but that's a different post altogether. Searching the forum now.
