Did you know that on the BT3000 . . .
    • 8774
    That some of the screws for the BT3000/3100 are Tri-sided? This could have been mentioned way back when, but I never noticed that, or at least I don't remember it.
    I took my BT3000 apart just before I left Japan - sides, motor / blade housing off; top off from the housing, the bevel gear, etc. Well, I am just now putting it back together. All screws were seperated into little bags according to its particular function. Today, I finally had some time to put it together and I noticed that one of the screws looked funny. Then I noticed several. Those that thread into aluminum are kinda tri-sided.
    Kinda proud of myself. I did not have a manual but got it together without a hitch. Two small blunders - the front switch - the box behind the wall I initially installed it upside down, but quickly discovered the problem as I tried to install the side plug in. Only took a minuted to fix. The front lever that changes from Bevel to Height, I put it on at the wrong angle, as I was re-building it up side down. I installed the lever to hang straight down when locked, but discovered it needs to be at an angle. Not a big problem, I will fix that next week. I haven't put the toggle levers for the rails on and of course I have not squared it. I will mount it on a Bosch gravity rise stand.
    • 4715
    I read somewhere that the tri-sided screws were self tapping. Guess the idea is they swage threads into the aluminum.
    • EngrChrisSaw
      Handtools only
      • Feb 2012
      • 4
      • Craftsman 113.298240, (Would like to try the Delta T2 mod) - Craftsman 21829
      Yes, they are self-tapping, but I also heard the screws will not have the same gripping power before removal. In worst cases, drilling and taping with a larger screw can be necessary.
        • 22011
        Huh, Hank?
        You mean they're self-tapping with three cutters on the threads?
        Or a head with a tri-wing (Y-shaped recess like a phillips but with three instead of four)
        or a head with Triangle recess?
        I presume you mean self-tapping with three cutters. I suppose the cutters slot/recess are for cuttings relief. The more the easier it would be to cut.
          • 8774
          Huh, Hank?
          The main shaft/body of the screw is kinda triangular shaped. It is a rounded over triagular, and obvious when looking specifically at the body. The wings/cutters are more round. I have a long day today but tomorrow (Tuesday evening) I will be able to hopefully take a picture of one of the screws. Although it is together, I can take one out easily enough and photo it.
            They are split self tapping screws. The splits allow for clearing if there is a collection of material.
              • 4715
              Nice guess but wrong.
              • woodturner
                • Jun 2008
                • 2049
                • Western Pennsylvania
                I think you are referring to trilobular thread rolling screws something like these. The shaft cross section is not round but more triangular with rounded corners.
                  • 8774
                  That is very close, if not the same. I am not at home and won't be there until late tonight. It will be tomorrow evening before I have time to check and photograph one.
                    "trilobular"
                    A new word for my thesaurus. It sounds like something I would make up, but use anway because it is self-desribing.
