Hi all,
I noticed that my cross cuts are not as square as I like it to be. So I brought out the manual to check and align the smt. For some reason, no matter how much I try, I could not get a clean square cut. Here are what I've done and results:
- Checked that fence is parallel to blade. They perfectly are and I'm very happy with any cut made using the fence.
- Using the Phil Thein's method (http://www.jpthien.com/3k.htm -- using a dial caliper instead of dial indicator, but the method is the same), checked that the smt base is parallel to the blade. They are.
- Using Phil Thein's method, square the miter fence to the blade as well as eliminating any play. - Cut a piece -- NOT SQUARE.
- Using an adjustable square (that I know is square using the scribe then flip method), check and re-square the miter fence to the blade again. It was square, indicating that Phil Thein's method worked, but I moved it around and re-square it.
- Cut a piece -- STILL IS NOT SQUARE.
- Repeat the last 4 steps a few times, then quit before I lost it.
The cuts tend to have an acute angle. At 6" from the base, there would be a gap roughly 1/32". I'm not sure what I'm doing wrong. Any thought is appreciated.
Thanks guys.
Thanks guys.
