Mounted saw
  • CaptRandy
    • Apr 2011
    • 27
    • Warrington PA/Ocean City NJ
    • skil
    Mounted saw
    Mounted saw on a wood platform like Jeff Browning's and plan to put rollers on bottom of carcase. Wanted ideas on casters. 2 of them swivel the other two are stationary. Should the swivels be in front and the stationary ones be on rear of box unit? And which way should I face the stationary wheels front to back or side to side?
    Hopefully someone has encountered this quandary and has an insightful opinion.
    • 22018
    when you roll the unit you will want to be able to go thru as narrow an area as possible therefore put the fixed casters at one end and the swivel ones at the other end so you can push the skinny side of the saw system in the direction along the long axis of the saw.
    If there's a heavy end then put the fixed ones at the heavy end, it will be easier to steer pushing the light swivel end right and left.
    • CaptRandy
      • Apr 2011
      • 27
      • skil
      Thanks, will do it that way. I was over thinking it until you pointed it out.
        I built a mobile base for my band saw with fixed casters on one end and found it hard to steer in close quarters. All the rest of my tools/equipment ride on 4 swivels. Much easier to steer and park. The jointer, edge sander, and band saw are on a lift type base. I have lifts made, but not installed for the table saw. The drill press, drum sander/planer cart, and router table have dual lock casters at the front corners.
        Casters is not the place to scrimp on the cost. Casters from HF and the box stores have inferior bearings on the swivels and won't handle any where near the claimed capacity. For lighter loads, I use the red poly casters from Grizzly. About the same quality as the ones sold by Woodcraft but at around 1/2 the costs. My heavier loads ride on Darnell Rose casters. Around $12 - $15 each plus shipping but the quality makes them worth the price in my mind. Also, Darnell Rose will custom build casters to your specs.
        • CaptRandy
          • Apr 2011
          • 27
          • skil
          Have a Grainger around the corner will check out what they have.
          • RAV2
            • Aug 2007
            • 233
            • Massachusetts
            • 21829
            Harbor Freight - combine a coupon and they can't be beat!
              I wouldn't put HF casters under anything I planned to actually move.
                • 22018
                +1 on that. Lots of good casters out there, but HF has mined the low end on these and life with bad casters is miserable. I'd buy any number of things HF but I won't trust their casters even at a low price plus an additional discount. Too hard to change your mind once they're in use!
                • CaptRandy
                  • Apr 2011
                  • 27
                  • skil
                  I actually took a set off of my Snap On roller box and used them. The roller box is in a corner and never moves.
